はじめに
An easy step by step guide on how to disassemble the Blitz Pro 800W blender.
== Key areas include==:
Red circles - Areas to focus on (eg. located where the screws would be unscrewed from section or removed).
Green areas - Indicating areas where the dissembler would grip with their hand (eg. where the main component divides into different sections).
必要な工具と部品
Unplug the device from the wall and turn the powerbase upside down.
CAUTION: Make sure the cord is not plugged into the outlet in order to prevent electrocution.
CAUTION: Make sure the cord is also wrapped up to eliminate the risk of tripping.
Place the blade firmly into a vice, allowing the grey circular turning mechanism to face upwards.
Turn clockwise with multi-grip pliers the grey circular turning mechanism, until it detaches from the white plastic base.
CAUTION: Make sure a strong grip is applied to the component in order to minimise injury.
Securely tighten white plastic base into a vice.
CAUTION: Do not tighten the white plastic base too tightly into the vice, as the part will be more prone to cracking and snapping.
Gently, but repeatedly (using a Flathead screwdriver and a rubber hammer), with minimum force, slowly tap the bearings around the circumference (located in the red circle) until they pop out.
コメント 1 件
I need a new silicone gasket. I am surprised how soon it broke in half. Am I supposed to wash it separately after each use or not? Can I buy a generic replacement as seen on Ali Express instead of $12 for one? What size would I need? Thanks
