メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのSynthesizersを修理する際は、iFixitの修理ガイドをご利用ください。
  1. KORG Volca Sample Teardown, Remove the screws on the bottom: 手順 1、 2の画像 1 KORG Volca Sample Teardown, Remove the screws on the bottom: 手順 1、 2の画像 2
    • Remove seven Screws.
    • Then turn the Volca around. You can now remove the two PCBs. Take care with the loudspeaker cable and the battery cable. In my picture the black cable is already loose.
  2. KORG Volca Sample Teardown, The PCB with the knobs and the main logic: 手順 2、 1の画像 1
    • This is the main processor. It is an Cypress FM4-Series MB9BF164L.
    • 25Q03213
    • The DAC. AKM4384FT.
    • MV3241 / 49AG3 / P220
  3. KORG Volca Sample Teardown, The PART, MUTE, FUNC, WRITE etc. buttons: 手順 3、 2の画像 1 KORG Volca Sample Teardown, The PART, MUTE, FUNC, WRITE etc. buttons: 手順 3、 2の画像 2
    • This is how working buttons should look like.
    • If this isn't the case, clean these parts with a Q-Tip dipped in isopropanol.
    • Clean these parts as well.
  4. KORG Volca Sample Teardown: 手順 4、 2の画像 1 KORG Volca Sample Teardown: 手順 4、 2の画像 2
    • Here is a complete overview of the PCB containing the Step Touch Buttons and the FUNC and WRITE buttons
作成者
2人の作成者と共同で作成されました。
Christian
メンバー登録日: 03/09/14
1,510 ポイント
8のガイドは作成済み
27 件のコメント
Hello, thanks for this post. I have an issue with my volca sample, only sound left is outputting. can you show me where the audio jack output circuit is ? Would be much appreciated. I think it’s a spike made by my soundcard while turnung it on that caused this issue.
Orphée Design - 返信
Sorry, I can’t help you here. You may try www.korgforums.com. There are some discussions about broken Volcas.
Christian -
Hi,
My Volca Sample LCD is dimmed (knob lights are not working too, however button lights works) after accidentally liquid spill. Everything else is fine. Can you give me some tip about dimmed LCD? Tnx
Flick Simpson - 返信
Hi, you can try open the Volca and rinse it thouroughly with distilled water. Remove the batteries before. Then dry it with a fan and keep it open and let it dry on air for 24 hours. The re-insert the batteries and hope for the best. What kind of liquid was it?
Christian -
Hello!! I have an issue with my VS. The Button 7 keeps triggering without no reason and is a pain in the ass. I opened the VS and cleaned all the pads ans circuits but doesn´t seem to do anything. :(
rodtop350z - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 86
今までの合計 6,690
