メインコンテンツにスキップ
IBM ThinkPad T42 Teardown
必要な工具と部品
  1. IBM ThinkPad T42 Teardown, Complete Disassembly: 手順 1、 3の画像 1 IBM ThinkPad T42 Teardown, Complete Disassembly: 手順 1、 3の画像 2 IBM ThinkPad T42 Teardown, Complete Disassembly: 手順 1、 3の画像 3
    • Removing the battery
    • Unplug the power cable before removing the battery.
    • Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
    • Grasp the battery and pull it straight out - not at an angle.
  2. IBM ThinkPad T42 Teardown: 手順 2、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 2、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 2、 3の画像 3
    • Removing the Hard Drive
    • Unscrew the screw holding the Hard Drive slot in place.
    • Pull the hard drive out with the help of pictured ridges. Cautiously maneuver it out - it might help to open the display slightly.
  3. IBM ThinkPad T42 Teardown: 手順 3、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 3、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 3、 3の画像 3
    • Removing the Optical Drive
    • Remove the screw holding the optical drive on the underside of the laptop
    • Push the small slider to unlock position, a tab will automatically pop out.
    • Pull tab to dislodge the optical drive, then pull the drive out.
  4. IBM ThinkPad T42 Teardown: 手順 4、 2の画像 1 IBM ThinkPad T42 Teardown: 手順 4、 2の画像 2
    • Removing Memory Cover/Replacing RAM
    • Unscrew the pictured screwed holding the memory cover in place.
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up. -picture of RAM inside -
    • Pull the stick out carefully. - Picture of the RAM stick -
  5. IBM ThinkPad T42 Teardown: 手順 5、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 5、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 5、 3の画像 3
    • Removing Rear Cover
    • Unscrew the rest of the screws on the underside of the T42.
    • Unscrew the 4 screws on either side the rear end of the laptop.
    • Note: for ease of reassembly, keep track of which screws go where.
    • [ a line-drawing version is included so it can be printed and screws can be taped on ]
    I wouldn't start with a complete removal of all screws. The IBM/Lenovo hardware manual shows which screws to remove to get to what part.
    Yishai Sered - 返信
  6. IBM ThinkPad T42 Teardown: 手順 6、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 6、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 6、 3の画像 3
    • Removing Keyboard and Trackpad
    • Flip the laptop over and open the display carefully - the keyboard, palm rest and bezel will be loose.
    • Maneuver the palm rest away from the keyboard carefully, both the keyboard and palm rest/trackpad will come off together.
    • **WARNING** Both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  7. IBM ThinkPad T42 Teardown: 手順 7、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 7、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 7、 3の画像 3
    • From here you can remove multiple components.
    • Removing Wi-Fi Card
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
    • Carefully pull it out.
  8. IBM ThinkPad T42 Teardown: 手順 8、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 8、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 8、 3の画像 3
    • Removing Mini-PCI Port
    • Unscrew the screw holding the port's bracket down, then remove the bracket.
    • Carefully disconnect it from the motherboard.
  9. IBM ThinkPad T42 Teardown: 手順 9、 2の画像 1 IBM ThinkPad T42 Teardown: 手順 9、 2の画像 2
    • Removing Top Plastic
    • Starting from the bottom right, carefully pry off the bezel. Use a small, flathead screwdriver if necessary.
  10. IBM ThinkPad T42 Teardown: 手順 10、 2の画像 1 IBM ThinkPad T42 Teardown: 手順 10、 2の画像 2
    • Removing the Display
    • To remove the display, unscrew the screws holding it down. Along with the one pictured, there is another one on the top right edge.
    • Carefully unplug the its connection with the motherboard.
    • Now it will be free to move. Carefully maneuver it out.
    el cable bt como lo conecto el monitor a la placa
    Fernando - 返信
  11. IBM ThinkPad T42 Teardown: 手順 11、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 11、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 11、 3の画像 3
    • Removing Lower Bracket
    • The bracket will be free to move, so remove it.
    • Then remove the small rubber piece covering the small battery.
  12. IBM ThinkPad T42 Teardown: 手順 12、 2の画像 1 IBM ThinkPad T42 Teardown: 手順 12、 2の画像 2
    • Removing Speakers
    • This component is free to move, so disconnect it's connector and pull it out carefully.
  13. IBM ThinkPad T42 Teardown: 手順 13、 2の画像 1 IBM ThinkPad T42 Teardown: 手順 13、 2の画像 2
    • Removing Fan
    • Unscrew the three shown screws, then unplug its connection with the motherboard.
    • **Since both the processor and graphics processor unit are attached to this fan with thermal paste, removing the fan might require some force and a flathead screwdriver to separate the paste from the fan.
  14. IBM ThinkPad T42 Teardown: 手順 14、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 14、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 14、 3の画像 3
    • Removing Processor
    • After removal of the fan, you have access to the processor. Locate its locking mechanism.
    • Use a flat head screwdriver and twist it carefully to the "unlocked" position.
    • Carefully pull the processor out.
    • ***CAUTION - If replacing the processor, make sure the small arrow on the corner aligns with socket.
    Como retirar las bosinas
    Pavel Duany - 返信
  15. IBM ThinkPad T42 Teardown: 手順 15、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 15、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 15、 3の画像 3
    • Removing Modem Daughter Card
    • Unscrew three phillips screws as shown.
    • The connector cables are wrapped around components for organization so follow these, unplug them and carefully pull them free.
    • Then remove the bracket that was sitting beneath it.
  16. IBM ThinkPad T42 Teardown: 手順 16、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 16、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 16、 3の画像 3
    • Removing Metal Casing
    • Unscrew the Philips head screws as shown
    • It is attached to the smaller black plastic piece below it - carefully maneuver both of them out at the same time.
    Does this give you open access to the IDE port?
    Evan Nayee - 返信
  17. IBM ThinkPad T42 Teardown: 手順 17、 1の画像 1
    • Removing Plastic
    • This will be free to move, so pull it out.
  18. IBM ThinkPad T42 Teardown: 手順 18、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 18、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 18、 3の画像 3
    • Removing Motherboard
    • Unscrew Phillips screws shown in red in the picture.
    • Unplug the connector (shown in turquoise)
    • Carefully remove the board
  19. IBM ThinkPad T42 Teardown: 手順 19、 3の画像 1 IBM ThinkPad T42 Teardown: 手順 19、 3の画像 2 IBM ThinkPad T42 Teardown: 手順 19、 3の画像 3
    • Congratulations
    • Now you're left with the motherboard and the bottom casing
    • This is as far as the teardown goes.
終わりに
To reassemble your device, follow these instructions in reverse order. Remember when reassembling to apply a thin layer of thermal compound on the CPU block.
17 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
eric
メンバー登録日: 04/17/10
591 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G76
4 メンバー
35のガイドは作成済み
2 件のコメント
Excelent, it help me so much.
MarhezCN - 返信
Great guide on how to take apart a computer!
Gabriel Pettis - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 65
今までの合計 39,002
