はじめに
Game Boy Advanceの全てのコンポーネントや解体情報です。
必要な工具と部品
スパッジャー、ピンセットもしくは爪先で、側面のグレーのタブを上方に(PCBの上端に向かって)引いて、LCDリボンポートのラッチを外します。
LCDリボンポートが外れたら、LCDリボンは簡単に側面から取り出せます。
Guide does not indicate that the ribbon cable port should be UNLATCHED before attempting to remove the ribbon cable, I strongly suggest revising this as someone unfamiliar with these style of ports may assume that the ribbon cable is a compression fit and just needs to be "pulled" free of the port.
This is a terrible idea that will potentially result in tearing the ribbon! Please consider revising guide to add a step to indicate the proper method/detail for unlatching the LCD ribbon port! Thanks :)
スパッジャーを使ってフロントパネルからスクリーンを持ち上げます。スパッジャーをDパッド左側の隙間に差し込みます。
This is a BAD place to pry on a functioning LCD. I used this exact method, slowly and carefully, and my LCD shattered.
Instead, remove the lens (it’s worth it to sacrifice the lens adhesive to save your LCD), and gently and slowly press with a gloved thumb on a corner to push it through from the front of the Game Boy. Let the adhesive release itself, don’t force it. If the room is super quiet, you should be able to hear a faint peeling sound, even if you can’t see anything moving. That means you’re doing it right; just wait and it will release.
Actually you can just pry under the ribbon cable. The LCD has a metal frame there that allowed me to slowly and carefully pry from that point without (re)breaking my LCD.
Yep. Same thing just happened to me :(
以下の翻訳者の皆さんにお礼を申し上げます:
92%
翻訳を始める ›
7 件のコメント
I dont understand. The items in “Tools featured in this teardown" is different from the tools written on the article e.g. Y0 in “featured" but Y1 in the “article”.
Great guide. My dumb ass didn’t see the screws holding the circuit board to the front shell lmao
RikaSprout - 返信
What is the cpu
How do you remove the CPU and SRAM chips?
