メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのGame Boy Advanceを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Game Boy Advance Teardown, Game Boy Advance Teardown: 手順 1、 3の画像 1 Game Boy Advance Teardown, Game Boy Advance Teardown: 手順 1、 3の画像 2 Game Boy Advance Teardown, Game Boy Advance Teardown: 手順 1、 3の画像 3
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Game Boy Advance Teardown: 手順 2、 1の画像 1
    • Remove the six back panel screws using a Y1 screw driver.
  3. Game Boy Advance Teardown: 手順 3、 1の画像 1
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Game Boy Advance Teardown: 手順 4、 1の画像 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Game Boy Advance Teardown: 手順 5、 2の画像 1 Game Boy Advance Teardown: 手順 5、 2の画像 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Teardown: 手順 6、 2の画像 1 Game Boy Advance Teardown: 手順 6、 2の画像 2
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Teardown: 手順 7、 1の画像 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
    some motherboards only have 2 screws holding it in place. keep this in mind if you cant find one
    Max R. - 返信
  8. Game Boy Advance Teardown: 手順 8、 2の画像 1 Game Boy Advance Teardown: 手順 8、 2の画像 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Game Boy Advance Teardown: 手順 9、 3の画像 1 Game Boy Advance Teardown: 手順 9、 3の画像 2 Game Boy Advance Teardown: 手順 9、 3の画像 3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Game Boy Advance Teardown: 手順 10、 3の画像 1 Game Boy Advance Teardown: 手順 10、 3の画像 2 Game Boy Advance Teardown: 手順 10、 3の画像 3
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
    Guide does not indicate that the ribbon cable port should be UNLATCHED before attempting to remove the ribbon cable, I strongly suggest revising this as someone unfamiliar with these style of ports may assume that the ribbon cable is a compression fit and just needs to be "pulled" free of the port.
    This is a terrible idea that will potentially result in tearing the ribbon! Please consider revising guide to add a step to indicate the proper method/detail for unlatching the LCD ribbon port! Thanks :)
    Ben Steel - 返信
  11. Game Boy Advance Teardown: 手順 11、 3の画像 1 Game Boy Advance Teardown: 手順 11、 3の画像 2 Game Boy Advance Teardown: 手順 11、 3の画像 3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
    This is a BAD place to pry on a functioning LCD. I used this exact method, slowly and carefully, and my LCD shattered.
    Instead, remove the lens (it’s worth it to sacrifice the lens adhesive to save your LCD), and gently and slowly press with a gloved thumb on a corner to push it through from the front of the Game Boy. Let the adhesive release itself, don’t force it. If the room is super quiet, you should be able to hear a faint peeling sound, even if you can’t see anything moving. That means you’re doing it right; just wait and it will release.
    trevorsklar - 返信
    Actually you can just pry under the ribbon cable. The LCD has a metal frame there that allowed me to slowly and carefully pry from that point without (re)breaking my LCD.
    trevorsklar - 返信
    Yep. Same thing just happened to me :(
    Robert Carlson - 返信
  12. Game Boy Advance Teardown: 手順 12、 1の画像 1
    • Use the tweezers to remove the black tape if needed.
作成者
10人の作成者と共同で作成されました。
Adam
メンバー登録日: 01/20/10
815 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S16G29
5 メンバー
61のガイドは作成済み
7 件のコメント
used this to replace the case and buttons on my GBA worked like a charm thanks!
Josh - 返信
I dont understand. The items in “Tools featured in this teardown" is different from the tools written on the article e.g. Y0 in “featured" but Y1 in the “article”.
darelldechavez - 返信
Great guide. My dumb ass didn’t see the screws holding the circuit board to the front shell lmao
RikaSprout - 返信
I am having difficulty determining the size of the Tri-Point screws used on the Game Boy Advance. As a previous commenter noted the screw driver listed as “Tools Featured in this Teardown” shows a size of Y0, but in the text of the teardown it shows Y1. Can someone please clarify?
bhandl1 - 返信
How do you remove the CPU and SRAM chips?
Steven Steele - 返信
コメントを追加
統計データ:
過去 24時間: 30
過去 7 日: 226
過去 30 日: 938
今までの合計 71,333
