メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのFranklin MWD-460Aを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Franklin MWD-460A Teardown, Fully Assembled: 手順 1、 2の画像 1 Franklin MWD-460A Teardown, Fully Assembled: 手順 1、 2の画像 2
    • Here is the fully assembled Franklin MWD-460A Electronic Dictionary.
  2. Franklin MWD-460A Teardown, Battery Compartment: 手順 2、 3の画像 1 Franklin MWD-460A Teardown, Battery Compartment: 手順 2、 3の画像 2 Franklin MWD-460A Teardown, Battery Compartment: 手順 2、 3の画像 3
    • On the back of the case, locate the battery compartment, its cover, two grooves, and the tab (which locks the cover in place).
    • Release the cover by pulling down on the tab with a fingernail.
    • While holding the tab down, insert the opening tool into one of the grooves and gently pry the cover off.
  3. Franklin MWD-460A Teardown, Separating the Panels Part 1: 手順 3、 3の画像 1 Franklin MWD-460A Teardown, Separating the Panels Part 1: 手順 3、 3の画像 2 Franklin MWD-460A Teardown, Separating the Panels Part 1: 手順 3、 3の画像 3
    • Locate the battery grooves.
    • Remove the batteries by inserting the prying tool into the grooves (sliding it underneath the batteries).
    • Locate the one screw inside the battery compartment, loosen it, and remove it.
  4. Franklin MWD-460A Teardown, Separating the Panels Part 2: 手順 4、 3の画像 1 Franklin MWD-460A Teardown, Separating the Panels Part 2: 手順 4、 3の画像 2 Franklin MWD-460A Teardown, Separating the Panels Part 2: 手順 4、 3の画像 3
    • Locate the six tabs holding the two panels together along the sides.
    • Insert the prying tool into each of the six grooves and gently separate each tab from its insert on the other panel.
    • Finally, separate the panels from one another.
  5. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: 手順 5、 3の画像 1 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: 手順 5、 3の画像 2 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: 手順 5、 3の画像 3
    • Locate the three screws holding the upper circuit board in place.
    • Loosen and remove the three screws.
    • The screw in the top right corner is also holding a tab in place so remember where it goes.
  6. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1 Continued: 手順 6、 1の画像 1
    • Gently lift the upper circuit board to locate the up/down keypad and remove it.
    • Be careful when moving the upper circuit board as it's attached to the LCD screen and the lower circuit board.
  7. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 2: 手順 7、 1の画像 1
    • Locate the eight screws holding the lower circuit board in place.
    • Gently pull up on the tape to expose the eighth screw.
    • Loosen and remove the eight screws along with their washers.
  8. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: 手順 8、 2の画像 1 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: 手順 8、 2の画像 2
    • Gently lift the two circuit boards (along with the attached LCD screen) away from their case.
    • Now peel the lower keypad from its case.
  9. Franklin MWD-460A Teardown, Full View of Disassembly: 手順 9、 1の画像 1
    • Here is a full view of the disassembled Franklin MWD-460A Electronic Dictionary.
作成者
3人の作成者と共同で作成されました。
Chris L
メンバー登録日: 12/17/14
1,522 ポイント
3のガイドは作成済み
コメント 1 件
How can I fix the screen? The letters are so faded. :(
Paola Paniagua - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 1,168
