メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのFitBit Surgeを修理する際は、iFixitの修理ガイドをご利用ください。
  1. FitBit Surge Teardown, The Surge: 手順 1、 2の画像 1 FitBit Surge Teardown, The Surge: 手順 1、 2の画像 2
    • Fitbit's latest fitness "super watch" has some pretty nice features, including:
    • Built-in GPS
    • Wrist-based optical heart rate monitor
    • Wireless syncing to smartphone or computer
    • 7+days of battery life without gps and up to 7h with gps (according to some reviews)
  2. FitBit Surge Teardown, Removing the bands: 手順 2、 3の画像 1 FitBit Surge Teardown, Removing the bands: 手順 2、 3の画像 2 FitBit Surge Teardown, Removing the bands: 手順 2、 3の画像 3
    • Remove the four screws
    • The bands are glued pretty well so you need to cut your way through to remove them and expose the fibit body
    • Cutting through the middle and lifting sideways worked pretty well
  3. FitBit Surge Teardown, GPS antenna: 手順 3、 3の画像 1 FitBit Surge Teardown, GPS antenna: 手順 3、 3の画像 2 FitBit Surge Teardown, GPS antenna: 手順 3、 3の画像 3
    • Once you remove the bands scrape away the glue on the top side to expose the GPS antenna
  4. FitBit Surge Teardown, Bluetooth antenna: 手順 4、 2の画像 1 FitBit Surge Teardown, Bluetooth antenna: 手順 4、 2の画像 2
    • On the other band you'll find the bluetooth antenna which is actually a flexible antenna glued to the inside of the band.
    • This antenna can be left on the surge if you try to detach wrist band by fitting something thin between front glass and the band.
  5. FitBit Surge Teardown, Opening the body: 手順 5、 3の画像 1 FitBit Surge Teardown, Opening the body: 手順 5、 3の画像 2 FitBit Surge Teardown, Opening the body: 手順 5、 3の画像 3
    • With the bands out of the way it's time to go inside Fitbit's guts
    • Remove the four metal parts as shown in the photo
    • After that just insert a screw driver or other sharp object into the fissure and voilá
  6. FitBit Surge Teardown, Touchscreen controller: 手順 6、 2の画像 1 FitBit Surge Teardown, Touchscreen controller: 手順 6、 2の画像 2
    • Right after splitting Fitbit into 2 the first component is immediately exposed
    • Cypress CY8CTMA463 touchscreen controller
  7. FitBit Surge Teardown, Microcontroller: 手順 7、 3の画像 1 FitBit Surge Teardown, Microcontroller: 手順 7、 3の画像 2 FitBit Surge Teardown, Microcontroller: 手順 7、 3の画像 3
    • After removing the large shield on the main PCB the brains of the gadget become visible
    • Silicon Labs EFM32 Giant Gecko (ARM Cortex-M3) EFM32GG395F1024
    • Micron Serial NOR Flash N25Q064A11ESEA0F
    • (Cypress touchscreen controller still visible here plugged into the main PCB)
  8. FitBit Surge Teardown, The other side: 手順 8、 2の画像 1 FitBit Surge Teardown, The other side: 手順 8、 2の画像 2
    • After removing the battery holder the main PCB can be carefully dislodged from the plastic body
    • Texas Instruments Battery Charger BQ24232H
    • MediaTek GPS Receiver MT3339 (couldn't find any datasheet, just a press release on it)
    • Texas Instruments Bluetooth Controller CC2564
  9. FitBit Surge Teardown, LCD and back side: 手順 9、 2の画像 1 FitBit Surge Teardown, LCD and back side: 手順 9、 2の画像 2
    • The LCD is secured with 3 very visible screws on the bottom side
    • Sharp TFT-LCD LS013B7DH01
  10. FitBit Surge Teardown, Family photo: 手順 10、 1の画像 1
    • Here are all the parts after the teardown
作成者
7人の作成者と共同で作成されました。
Tiago Monte
メンバー登録日: 05/26/15
88 ポイント
1ガイドが承認済み
52 件のコメント
Any idea about the sensors? The heart rate sensor is obvious, and I'm sure there are accelerators. I think the white topped part near the TI battery charger is an altimeter. Anything else on there that anyone recognizes?
Chris Arney - 返信
Hi Chris,
Yes it's a MS5805-02BA01 pressure sensor.
I've been trying to repair a Fitbit charge and the device had a dry joint. Sadly I was unable to repair it. Bin job :(
Russell Gibb -
Could you show photos of the area where the Heart Rate Sensor is located. It is Seen clearly in Step5 - first picture. Is it a custom sensor or does it use a 3rd party sensor
Fitbit Wearer - 返信
Is it possible to replace the glass that goes over the screen?
Tim - 返信
@Tim: yes, I would like to know the same thing? Is it possible to replace a cracked screen and if so, how much is the part?
idaho112233 -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 110,241
