メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのFanを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Fan Teardown, Fan Teardown: 手順 1、 1の画像 1
    • The image displayed to the left of the screen portrays a mobile fan in pristine condition.
  2. Fan Teardown: 手順 2、 1の画像 1
    • The Guard of the fan is detached from its base due to the effectiveness of a screwdriver.
  3. Fan Teardown: 手順 3、 1の画像 1
    • As seen in the photograph to the left, the blade of the fan has been removed from its guard.
  4. Fan Teardown: 手順 4、 1の画像 1
    • The image to the left of the screen displays the guard of the fan conspicuously detached from the fans base. Various screws are spread across the canvas due to their removal.
  5. Fan Teardown: 手順 5、 1の画像 1
    • We have diverted our focus in disassembling components mainly involved with the fans blade and have begun to focus on "tearing down" the fans motor and shaft.
  6. Fan Teardown: 手順 6、 1の画像 1
    • The photograph which lays on the left of the screen displays the process of tearing down the initial motor of the mobile fan.
  7. Fan Teardown: 手順 7、 1の画像 1
    • The casing which covered the interior of the motor has now been removed through the use of a screw to gain access to its interior.
  8. Fan Teardown: 手順 8、 1の画像 1
    • Now that the casing has been removed, we have gained access to the motor's circuit board.
  9. Fan Teardown: 手順 9、 1の画像 1
    • We have removed the circuit board from the shell which enclosed it so we may study it further.
  10. Fan Teardown: 手順 10、 1の画像 1
    • All components of the fan have been disassembled...your task is now complete.
作成者
2人の作成者と共同で作成されました。
Jeffrey
メンバー登録日: 10/19/16
309 ポイント
2のガイドは作成済み
2 件のコメント
where did you get the fan?
Anrothan - 返信
I’m looking for a replacement fan blade for a reco(unireco) df-12ch fan, I can’t seem to find a website that has them to order.
Renata Weir - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 10
今までの合計 4,266
