はじめに
Teardown of an Epson Stylus Photo 820 Inkjet Printer.
必要な工具と部品
This is a teardown of the Epson Stylus 820 Photo color printer.
The main stepper motor, the part most likely to fail, is easy to remove.
The ink cartridges are easily replaceable.
Many parts inside the printer have ink on them, making repairs messy.
The other stepper motor is very hard to access and requires disassembling most of the printer.
The midframe, which contains the gearbox and secondary stepper motor, is attached to the case with blobs of melted plastic that must be cut off to remove.
The case is very hard and tedious to open without breaking tabs.
Bonus Teardown Time!
Time to see what is underneath the 'Do not remove' sticker located on the ink cartridge.
What is this network of labyrinthine passageways?
The answer is a capillary tunnel to reduce ink pressure. The lower row of holes leads into the cartridge itself, while the top row leads to the ink nozzles.
3件のガイドコメント
Thanks for sharing this blog with us.
Epson Stylus Photo R280 Ultra Hi-Definition Photo Printer is the fast, easy way to print brilliant, 4 x 6" photos or text documents.
Wavex is a US-based Coin that specializes in crypto-enabled financial services.
Nick Jones - 返信
