必要な工具と部品
The Emerson Research SmartSet alarm clock automatically sets the time through the power of black magic and voodoo when plugged in.
That pale blue display, while calming during the day, while be so bright as to make it nearly impossible to sleep at night.
That said, let’s tear it apart.
Carefully heat the glue along the plastic frame of the speaker. It will be difficult to heat the glue without deforming the plastic frame, as gratuitous amounts of glue were used and the frame wilts at the mere suggestion of heat. For those of you who can shoot fine lasers from your eyes, this would be a fine time to utilize that skill.
Pull the speaker away. If you’re patient, you might be able to pull out the speaker without damaging the frame too badly. If patience eludes you, as soon as you apply heat, get something to use as a wedge, start prying, and pray for the best.
Carefully heat and remove chime. This is much easier to remove than the speaker.
4 件のコメント
I have a cks3516 can’t set time. Is the power coming out of transformer d.c.? Want to test it! Thinking might be capacitor or cold solder joint! Any help or schematic would be lots of help! This is the projection clock radio! Thank you!
What does suffix D mean on the label. I seen some of the same model without it on the label. Is there a hidden function for home security? Like a microphone or small camera hidden to watch the room its in?
Brian Mahr - 返信
My old clock still works, but not bright enough anymore. Can I alter the circuitry a bit?
