はじめに
The R2-D2 humidifier is a fairly simple device to take apart. We will start with the preparation for the tear-down.
必要な工具と部品
Gently lift the cover off the humidifier
The LED is connected to a pin that is connected to the circuit board.
Upon close inspection, you can see that the LED's two ends are bent (red circle of the second image) to prevent it from slipping off of the pin.
Use blunt tweezers to bend and straighten the two ends.
Once the two ends are straight, gently pull the LED out of the pin.
Air humidifier "ATMOS-2630" refers to the type of ultrasonic devices for air humidification. This is a fairly new principle in the field of air humidification, which allows you to achieve high power with both low noise and power consumption. The product uses a piezoceramic element (converter), which is able to convert the electrical voltage of high frequency into mechanical (ultrasonic) oscillations.
Best Whole House Humidifiers
jeni johnson - 返信
