メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのDualShock 2を修理する際は、iFixitの修理ガイドをご利用ください。
  1. DualShock 2 Teardown+How It Works, DualShock 2 Teardown+How It Works: 手順 1、 3の画像 1 DualShock 2 Teardown+How It Works, DualShock 2 Teardown+How It Works: 手順 1、 3の画像 2 DualShock 2 Teardown+How It Works, DualShock 2 Teardown+How It Works: 手順 1、 3の画像 3
    • There are 6 screws that you will want to remove on the back of the Dualshock 2 controller. All pictures show the same thing essentially, but because of Ifixit's odd picture cropping system, every screw appears at least once throughout the 3 photos.
  2. DualShock 2 Teardown+How It Works: 手順 2、 3の画像 1 DualShock 2 Teardown+How It Works: 手順 2、 3の画像 2 DualShock 2 Teardown+How It Works: 手順 2、 3の画像 3
    • The casing should come right off, followed by the circuit board, the the white-plastic part. Make sure to keep track of all your buttons, as when you are taking it apart, they can be lost easily.
  3. DualShock 2 Teardown+How It Works: 手順 3、 3の画像 1 DualShock 2 Teardown+How It Works: 手順 3、 3の画像 2 DualShock 2 Teardown+How It Works: 手順 3、 3の画像 3
    • The first picture shows a fully deconstructed circuit board, while the second and third pictures shows the trigger board (the board which receives each individual input)
  4. DualShock 2 Teardown+How It Works: 手順 4、 2の画像 1 DualShock 2 Teardown+How It Works: 手順 4、 2の画像 2
    • In the first picture, you can see the bottom of the top shell of the Dualshock 2 controller. In the second one, you can see the joysticks without the rubber part.
  5. DualShock 2 Teardown+How It Works: 手順 5、 1の画像 1
    • How it works''' This little plastic bulge is actually just a piece of magnetized ferrite. What it does is allow for reduce electrical interference and thereby enable more efficient flow of electrons or electrical current to and from the device.
  6. DualShock 2 Teardown+How It Works: 手順 6、 1の画像 1
    • Each of these buttons has a tiny curved disk attached to its bottom. This disk is very conductive. When the button is pressed, the disk is pushed against a thin conductive strip mounted on the controller's circuit board.
    • If the button is pressed lightly, the bottom part of the curved disk is all that touches the strip, increasing the level of conductivity slightly. As the button is pressed harder, more of the disk comes into contact with the strip, gradually increasing the level of conductivity.
    • This varying degree of conductivity makes the buttons pressure-sensitive (meaning pushing the button harder does have some merit to it)!
  7. DualShock 2 Teardown+How It Works: 手順 7、 2の画像 1 DualShock 2 Teardown+How It Works: 手順 7、 2の画像 2
    • The final great feature about the dualshock 2 controller is it’s vibration feature. In a racing game, when you slam into a wall, you can feel the impact in your hands! The specific name for this is Force Feedback.This provides a tactile feature to the controller, allowing you to feel a sensation, even when you may not see it.
    • Force feedback is accomplished through the use of a very common device, a simple electric motor. In the Dualshock 2 controller, two motors are used, one in each handgrip. The shaft of each motor holds an unbalanced weight. When power is supplied to the motor, it the weight spins.
    • Because the weight is unbalanced, the motor tries to wobble. But since the motor is securely mounted inside the controller, the wobble translates into a shuddering vibration of the controller itself.
  8. DualShock 2 Teardown+How It Works: 手順 8、 1の画像 1
    • And, of course, all the power and inputs travel through this wire through what I believe is a series circuit.
作成者
1人の作成者と共同作成されました。
Supergamer5130 Z.
メンバー登録日: 04/13/18
227 ポイント
1ガイドが承認済み
コメント 1 件
Super je me suis toujours demandéé à quoi servait le “tube” sur le cordon !
Alexandra Lem - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 38
過去 30 日: 178
今までの合計 9,918
