メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのDell Optiplex GX620を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Dell Optiplex GX620 Teardown, Removing the side panel: 手順 1、 1の画像 1
    • Start by removing the side panel by rotating the blue knob in the direction of the arrow
  2. Dell Optiplex GX620 Teardown, Removing the floppy drive: 手順 2、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the floppy drive: 手順 2、 2の画像 2
    • Remove the floppy drive by pressing the marked knob.
    • There might be a screw on the underside of it.
    • Then pull on the tab that came out of the floppy drive to remove it.
  3. Dell Optiplex GX620 Teardown, Removing the hard drive: 手順 3、 3の画像 1 Dell Optiplex GX620 Teardown, Removing the hard drive: 手順 3、 3の画像 2 Dell Optiplex GX620 Teardown, Removing the hard drive: 手順 3、 3の画像 3
    • Remove the hard drive by squeezing the two blue tabs on the side.
    • Then pull the hard drive towards the front of the computer.
    • Pull out the two cables on the hard drive.
    • Then lift the hard drive up and out.
  4. Dell Optiplex GX620 Teardown, Removing blue cover: 手順 4、 2の画像 1 Dell Optiplex GX620 Teardown, Removing blue cover: 手順 4、 2の画像 2
    • Remove the blue cover with 'DELL' on it. by simply pulling it up and out.
  5. Dell Optiplex GX620 Teardown, Removing the hard drive bracket: 手順 5、 3の画像 1 Dell Optiplex GX620 Teardown, Removing the hard drive bracket: 手順 5、 3の画像 2 Dell Optiplex GX620 Teardown, Removing the hard drive bracket: 手順 5、 3の画像 3
    • Remove the hard drive bracket by unscrewing the two screws.
    • Slide the hard drive bracket to the left and then towards the front of the computer.
    • Unplug the connector for the switch. by pressing the little tab on the connector and pulling it up.
    • And lift the entire bracket out
  6. Dell Optiplex GX620 Teardown, Removing the back screws: 手順 6、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the back screws: 手順 6、 2の画像 2
    • Unscrew the four screws on the back.
  7. Dell Optiplex GX620 Teardown, Removing the motherboard tray: 手順 7、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the motherboard tray: 手順 7、 2の画像 2
    • Slide the back plate back, as shown in the picture.
    • And lift the motherboard tray up and out
  8. Dell Optiplex GX620 Teardown, Removing the fans: 手順 8、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the fans: 手順 8、 2の画像 2
    • Remove both fans by pressing the tab shown in the picture and sliding the fan in the direction shown.
    • Unplug the connector from the fan by pressing on the little tab on the connector and pulling it up. preferably by the housing of the connector, not the wires.
  9. Dell Optiplex GX620 Teardown, Removing the heatsink: 手順 9、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the heatsink: 手順 9、 2の画像 2
    • Pull back the black tab.
    • Quite a bit of force required
    • Pull the heatsink upwards.
  10. Dell Optiplex GX620 Teardown, Removing the CPU: 手順 10、 3の画像 1 Dell Optiplex GX620 Teardown, Removing the CPU: 手順 10、 3の画像 2 Dell Optiplex GX620 Teardown, Removing the CPU: 手順 10、 3の画像 3
    • Push down on the lever on the left hand side, and push it to the left.
    • Lift the lever up
    • And then lift the bracket up
    • Remove the CPU by lifting it straight up by the edges of the green PCB.
    • Be careful not to bed any of the pins of the CPU socket.
  11. Dell Optiplex GX620 Teardown, Removing RAM sticks: 手順 11、 3の画像 1 Dell Optiplex GX620 Teardown, Removing RAM sticks: 手順 11、 3の画像 2 Dell Optiplex GX620 Teardown, Removing RAM sticks: 手順 11、 3の画像 3
    • Remove the RAM sticks by pulling the white tabs away from the RAM sticks.
    • Pull up and the RAM stick, it should be loose now, if not redo step 1.
    • Do the same for the second RAM stick.
  12. Dell Optiplex GX620 Teardown, Removing the graphics heat sink.: 手順 12、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the graphics heat sink.: 手順 12、 2の画像 2
    • Remove the heat sink for the graphics chip by pressing the metal tab down and out of the hole.
    • Be VERY careful to keep the heat sink flat whilst removing it, otherwise you might crack the die.
  13. Dell Optiplex GX620 Teardown, Removing the heatsink bracket: 手順 13、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the heatsink bracket: 手順 13、 2の画像 2
    • Unscrew the four screws holding the bracket that holds the heatsink.
    • Be careful not to drop any screws in the CPU socket.
    • Remove the plastic bracket
  14. Dell Optiplex GX620 Teardown, Removing the CMOS battery: 手順 14、 2の画像 1 Dell Optiplex GX620 Teardown, Removing the CMOS battery: 手順 14、 2の画像 2
    • Remove the CMOS battery by pushing the tab marked in the picture to the left. And the battery will pop out.
    • using a screwdriver might help.
  15. Dell Optiplex GX620 Teardown, Removing the motherboard from the motherboard tray: 手順 15、 3の画像 1 Dell Optiplex GX620 Teardown, Removing the motherboard from the motherboard tray: 手順 15、 3の画像 2 Dell Optiplex GX620 Teardown, Removing the motherboard from the motherboard tray: 手順 15、 3の画像 3
    • Remove the three screws and two standoffs from the motherboard.
    • Lift the motherboard from the motherboard bracket.
    • Again be careful not to drop any screws in the CPU socket.
  16. Dell Optiplex GX620 Teardown, All the components: 手順 16、 1の画像 1
    • And there you have it, all the components of the Dell Optiplex GX620.
作成者
1人の作成者と共同作成されました。
G. van Marle
メンバー登録日: 11/17/20
253 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,778
