必要な工具と部品
Disconnect AC power adapter.
Push battery release tabs inwards, and slide the battery out of the computer.
Remove the two 2.8mm Phillips screws securing the hard drive.
Pull the hard drive out of the laptop.
Remove the 2.8mm Phillips screw securing the optical drive removal button.
Press the removal button on the side of optical drive.
Pull the Optical Drive out of the laptop.
Remove the one 7.5 mm Phillips screw securing the bottom case.
Pull the bottom lid towards yourself to remove it.
Remove the two 4.8mm Phillips screws securing the plastic lids.
Slide the plastic lids of the case.
Open your laptop so the display is perpendicular to the upper case.
Place your opened laptop on a table as pictured.
While holding the display and upper case together with your left hand, remove the two 4.8 mm Phillips screws from the display brackets.
Grab the upper case with your right hand and rotate the display slightly away from the upper case. Lift the display away from the upper case, minding any brackets or cables that may get caught.
Remove the four Phillips screws securing the heat sink.
Using your finger gently lift and remove heat sink .
Remove the seven 4.8 mm Phillips screws securing the upper case.
Remove the two 4.8 mm Phillips screws securing the upper case.
Remove the two Phillips screws holding the keyboard
Holding the plastic film gently lift the keyboard upwards to realise the side clips.
Pull the keyboard towards the screen to slide it out from the sockets.
Disconnect the keyboard and touchpad cable by holding plastic film and pulling the male end straight away from its socket.
Use the tip of a spudger to flip up the locking lever to release the contactless smart-card reader ribbon cable from its socket.
Pull the contactless smart-card reader ribbon cable straight away from the logic board.
Use the tip of a spudger to flip up the locking lever to release the smart-card reader ribbon cable from its socket.
Pull the smart-card reade ribbon cable straight out of its socket.
