メインコンテンツにスキップ
Dell Latitude 7420 Keyboard Replacement/Teardown
必要な工具と部品
  1. Dell Latitude 7420 Keyboard Replacement/Teardown, Remove backplate: 手順 1、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, Remove backplate: 手順 1、 2の画像 2
    • remove 8x screws with PH1 Screwdriver
    • Use finger nail or operning pick between backplate and frame at the top of the device
  2. Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: 手順 2、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: 手順 2、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: 手順 2、 3の画像 3
    • remove battery connector by pulling up. make sure the pulling strap is turned upwards
    • remove 5x screws with PH1
    • these are longer, do not mix them up!
  3. Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect speaker cable: 手順 3、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect speaker cable: 手順 3、 2の画像 2
    • remove speaker cable by pulling towards yourself horizontally
    • lift out the battery vertically.
  4. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: 手順 4、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: 手順 4、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: 手順 4、 3の画像 3
    • open ribbon cable connectors by lifting up and away from you the black securing latch
    • carefully lift up ribbon cables and pull towards yourself
  5. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect headphone jack daughter board: 手順 5、 1の画像 1
    • Insert wisdom here.
  6. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect fan: 手順 6、 1の画像 1
    • pull horizontally to the rigt
  7. Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 手順 7、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 手順 7、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 手順 7、 3の画像 3
    • Use JIS00 or J00
    • display connector
    • wifi antenna connector
  8. Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 手順 8、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 手順 8、 2の画像 2
    • use JIS00 or J00
    • unscrew connector plate
  9. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: 手順 9、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: 手順 9、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: 手順 9、 3の画像 3
    • lift upwards vertically
    • pull out horizontally away from you
  10. Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: 手順 10、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: 手順 10、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: 手順 10、 3の画像 3
    • remove 6x screws using PH1
    • remove cable sticker from heat sink
    • if the thermal paste has dried out the heat sink can be stuck on. carefully wiggle it horizontally until you can lift it up vertically
  11. Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard screws: 手順 11、 1の画像 1
    • use PH1 for 2x mobo screws
  12. Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: 手順 12、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: 手順 12、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: 手順 12、 3の画像 3
    • remove 4x USB Screws with PH1
  13. Dell Latitude 7420 Keyboard Replacement/Teardown, USB C daughter board screws: 手順 13、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, USB C daughter board screws: 手順 13、 2の画像 2
    • remove 2x with PH1
  14. Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: 手順 14、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: 手順 14、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: 手順 14、 3の画像 3
    • start on the right side at the USB C daughter board.
    • lift up the motherboard where the fan used to be
    • you should be able disconnect the daughterboard and mother board
    • the USB C port on the left might be tight. Use your fingers to slightly bend the laptop casing outward to the left above the usb c port
    • lift out the motherboard vertically
    • lift out USB C daughter board vertically. use the frame bending trick if necessary
  15. Dell Latitude 7420 Keyboard Replacement/Teardown, remove headphone jack daughter board: 手順 15、 1の画像 1
    • remove 1x screw with PH1
    • lift out daughter board vertically
  16. Dell Latitude 7420 Keyboard Replacement/Teardown, unstick ribbon cables: 手順 16、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, unstick ribbon cables: 手順 16、 2の画像 2
    • carefully unstick glued on ribbon cables. use are card and pull up at 45° angle
    • no need to remove headphone jack cable
    • disconnect ribbon cable
    • be extremly careful not to pull at bends in the ribbon cables
  17. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: 手順 17、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: 手順 17、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: 手順 17、 3の画像 3
    • open connector as usual
    • the smaller ribbon cable has a different securing mechanism, look at the second image. it is opend from the other side
    • open connector from smaller ribbon cable at the white flap. NOT on top of the ribbon cable!
    • pull out ribbon cables
  18. Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: 手順 18、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: 手順 18、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: 手順 18、 3の画像 3
    • use JIS00 or J00 to remove 19x screws
    • go around perimeter of the backplate in a orderly fashion when removing the screws to not miss any
  19. Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard with backplate: 手順 19、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard with backplate: 手順 19、 2の画像 2
    • lift up keyboard vertically
    • be careful: ribbon cables might be sticky
  20. Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: 手順 20、 3の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: 手順 20、 3の画像 2 Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: 手順 20、 3の画像 3
    • use PH1 to unscrew backplate from front of keyboard
  21. Dell Latitude 7420 Keyboard Replacement/Teardown, clean CPU and Heat Sink: 手順 21、 2の画像 1 Dell Latitude 7420 Keyboard Replacement/Teardown, clean CPU and Heat Sink: 手順 21、 2の画像 2
    • remove old thermal paste using isopropyl alcohol and a cloth
    • apply new thermal paste
  22. Dell Latitude 7420 Keyboard Replacement/Teardown, backplate: 手順 22、 1の画像 1
    • keyboard backplate
    • when you are done with reassembly do not panic, the first boot takes a little longer after disconnecting the battery
    • after reassembly press inbetween keyboard keys to klick together backplate and notebook frame
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
fixer
メンバー登録日: 07/05/16
862 ポイント
3のガイドは作成済み
2 件のコメント
Steps 10 and 13 are not necessary (motherboard could be removed together with a head sink)
Alex - 返信
After following this very useful guide my new keyboard was not working, when you reconnect all the ribbon cable take some time to reconnect them better then I have done :-D
If something is not working double check the ribbon cables connection before doing anything else.
daniele - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 38
過去 30 日: 201
今までの合計 3,728
