メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Here I show you how to disassemble a Dell Inspiron N4050 Laptop
  1. Check your laptop model Turn it over to work on the bottom of the laptop Open the first latch for the battery
    • Check your laptop model
    • Turn it over to work on the bottom of the laptop
    • Open the first latch for the battery
  2. Open the second latch in the direction that the arrow is pointing. This requires more effort than the first one. The battery will come out a little. Finish removing it gently. The battery will come out a little. Finish removing it gently.
    • Open the second latch in the direction that the arrow is pointing. This requires more effort than the first one.
    • The battery will come out a little. Finish removing it gently.
  3. Remove the 8 screws. Use a Phillips 0 screwdriver.
    • Remove the 8 screws.
    • Use a Phillips 0 screwdriver.
  4. Turn the laptop with the keyboard facing up. Use a flat-blade screwdriver to separate the keyboard from the computer case. Tilt the keyboard as shown in the image. Do not remove it completely because it is connected to a cable.
    • Turn the laptop with the keyboard facing up.
    • Use a flat-blade screwdriver to separate the keyboard from the computer case.
    • Tilt the keyboard as shown in the image. Do not remove it completely because it is connected to a cable.
  5. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  6. Remove the clip that holds the cable to the motherboard. Remove the cable.
    • Remove the clip that holds the cable to the motherboard.
    • Remove the cable.
  7. Remove the memory cards by moving the retaining clips in the direction that the arrows are pointing. Remove the memory cards by moving the retaining clips in the direction that the arrows are pointing.
    • Remove the memory cards by moving the retaining clips in the direction that the arrows are pointing.
  8. Remove the 3 screws. Remove the 3 screws. Remove the 3 screws.
    • Remove the 3 screws.
  9. Remove the 2 small cables. Remove the 2 small cables. Remove the 2 small cables.
    • Remove the 2 small cables.
  10. Use a plastic tool to separate the top of the laptop. Use a plastic tool to separate the top of the laptop.
    • Use a plastic tool to separate the top of the laptop.
  11. CPU
    • CPU
    • DDR3 RAM memory, 2 slots avaiable
    • SATA hard disc
    • Heatsink
    • DVD unit
    • Wireless network card
    • Battery for the internal clock
終わりに
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
Marcos Mora
メンバー登録日: 2017年12月17日
698 ポイント
11のガイドは作成済み
コメント1件
thanks, very clear and useful
Zerumz - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 29
過去 30 日: 173
今までの合計 2,034
