はじめに
This guide will demonstrate how to apart the Dell Inspiron 15-7559.
必要な工具と部品
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Locate the WLAN card. It will be on the right sides of the laptop.
Using a Philips #1 screwdriver, unscrew the 2mm x 3mm screw, holding the WLAN card in place.
Using your hand disconnect the WLAN card by pulling it horizontally along the device.
After the WLAN card has been disconnected, make sure to dethread the wires connecting it so that they sit freely.
Using tweezers pull the metal tab, on the back of LCD connection point, away from it.
Once the metal tab is sufficiently released, pull the black strap to disconnect the LCD.
After the LCD has been disconnected, make sure to dethread the wires connecting it so that they sit freely.
7 件のコメント
Its really good work and Professional one. You can also expect the same from Ncentric systems which are offering the Computer and Laptop Repairing in Hyderabad
Seems a bit rude of them to make you take out the battery and hard drive in order to get to the fans; I tried to open mine up to dust off the inside, but I dont have a Torx screwdriver on me. Looks like I'll have to come back when I have one
I have the same question, where is the reed/ lid switch located?
Anyone know the size of the screws on the top of the hinge?
