はじめに
This is a low performance USB 2.0 HUB using 2 4-Port USB 2.0 HUBs chained together.
As Genesys Logic states:
"To fully meet the cost/performance requirement, GL850G is a single TT hub solution for the cost requirement. Genesys Logic also provides GL852 for multiple TT hub solution to target on systems which require higher performance for full/low-speed devices, like docking station, embedded system … etc.. Please refer to GL852 datasheet for more detailed information."
必要なもの
D-Link 7-Port USB 2.0 HUB Model No.: DUB-H7 H/W Ver.: C1 UPC Code: 790069252389
Charger
USB cable
To open the USB HUB there are only 4 screws below the two pads.
5 件のコメント
Anyone can tell what is the output voltage on this ? Mine shows 4.88V and I don't know if I should return it or not. My USB devices seem unstable.
I returned this low performance hub. But the USB spec says that voltage should be 5.00±0.25 V. So, voltage may not be the issue. If the device works correctly when directly connected to the computer, then just return the USB HUB, and upload a video (on youtube or somewhere else) so people can see the problem and not buy this low performance USB HUB.
If you need a high performance USB HUB just get this:
Juan -
Thanks for this! But I'm confused: is this single TT or multi TT?
Can anyone tell me what a good DVD burner I can buy to burn copy write disk
