はじめに
A look at the guts of the iPaq.
この分解は修理ガイドでは ありません。 お持ちのCompaq iPaq Pocket PC 3765を修理する際は、iFixitの修理ガイドをご利用ください。
  1. an original ipaq from compaq not hp
    • an original ipaq from compaq not hp
    • the teardown is realatively simple (PS: simply is not always easy)
  2. There are four torx screws here
    • There are four torx screws here
    • Gently pry around the edges to release the cover
    • The battery is glued to the back cover be careful not to damage the fragile ribbon cable
    • fold the back under the front panel and carefully remove the battery connector
    • x
    • Disconnect the backlight
    • from the inverter
    • here is an Htc branded processor
    • be sure to pop up the black wire
    • remove the stylus ejector
    • Gently pull on the top face while lifting the logic board (will require some force)
    • Be careful of the black wire running along the board
    • Disconnect the screen and digitizer cables being careful not to damage the cable or connector
    • two Intel flash chips
    • again putting pressure on the top panel lift the display out of the case
    • an htc branded control board
    • (funny I thought it said compaq on the front?)
    • The final product (destroyed that is)
    • I used NO anti-static precautions, reassembled the device and after finaly getting the video cable to lock in it worked fine
    • PS: the touch panel worked But when i fixed the video cable i knocked it loose and didnt realize it and now i have to fix it (sigh)
josh9623
メンバー登録日: 2010年08月27日
149 ポイント
1ガイドが承認済み
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 2,794
