メインコンテンツにスキップ
この分解は修理ガイドでは ありません。 お持ちのChristmas treeを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Christmas Tree Teardown, Christmas Tree Teardown: 手順 1、 1の画像 1
    • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
  2. Christmas Tree Teardown: 手順 2、 2の画像 1 Christmas Tree Teardown: 手順 2、 2の画像 2
    • First order of business: presents!
    • Use caution and joy when opening your presents.
  3. Christmas Tree Teardown: 手順 3、 2の画像 1 Christmas Tree Teardown: 手順 3、 2の画像 2
    • Disconnect the power plug
    • Remove the power socket, should there be one on your tree.
  4. Christmas Tree Teardown: 手順 4、 1の画像 1
    • To remove the baubles, lift them gently and untangle the string from the branch.
  5. Christmas Tree Teardown: 手順 5、 3の画像 1 Christmas Tree Teardown: 手順 5、 3の画像 2 Christmas Tree Teardown: 手順 5、 3の画像 3
    • If you find a capacitor on your christmas tree, straighten its leads to detach it.
    • All discrete electronic elements should be removed in this manner.
  6. Christmas Tree Teardown: 手順 6、 1の画像 1
    • Protective hand-wear may come in handy.
  7. Christmas Tree Teardown: 手順 7、 1の画像 1
    • Remain gentle, even when an element is very difficult to untangle.
  8. Christmas Tree Teardown: 手順 8、 2の画像 1 Christmas Tree Teardown: 手順 8、 2の画像 2
    • To remove the top ornament, lift it upwards.
  9. Christmas Tree Teardown: 手順 9、 1の画像 1
    • Finally, remove the lights.
    • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
  10. Christmas Tree Teardown: 手順 10、 2の画像 1 Christmas Tree Teardown: 手順 10、 2の画像 2
    • Before you run around barefoot in celebration, clean up.
    • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
    • The christmas tree is disassembled!
    • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
    • Thank you for reading, hope you are having a happy holiday.
    • Fix yourself a wonderful New Year in 2019!
作成者
5人の作成者と共同で作成されました。
baq
メンバー登録日: 10/14/09
305 ポイント
3のガイドは作成済み
コメント 1 件
skuirel sed it good!
Kyle Wiens - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 8,640
