メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのCaterpillar B15を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Caterpillar B15 Teardown, Caterpillar B15 Teardown: 手順 1、 1の画像 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 Teardown: 手順 2、 2の画像 1 Caterpillar B15 Teardown: 手順 2、 2の画像 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 Teardown: 手順 3、 2の画像 1 Caterpillar B15 Teardown: 手順 3、 2の画像 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  4. Caterpillar B15 Teardown: 手順 4、 2の画像 1 Caterpillar B15 Teardown: 手順 4、 2の画像 2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
  5. Caterpillar B15 Teardown: 手順 5、 1の画像 1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  6. Caterpillar B15 Teardown: 手順 6、 1の画像 1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  7. Caterpillar B15 Teardown: 手順 7、 1の画像 1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
  8. Caterpillar B15 Teardown: 手順 8、 1の画像 1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  9. Caterpillar B15 Teardown: 手順 9、 1の画像 1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  10. Caterpillar B15 Teardown: 手順 10、 1の画像 1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  11. Caterpillar B15 Teardown: 手順 11、 1の画像 1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
作成者
2人の作成者と共同で作成されました。
Geoffrey Mosdell
メンバー登録日: 10/06/14
1,119 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G7
4 メンバー
10のガイドは作成済み
2 件のコメント
Hi,
where can i buy T5 Torx screws for CAT B15 ?
Regards,
Laurent NOEL
Laurent NOEL - 返信
Any idea where I can get the rubber piece that covers the USB port? The one repair shop in the US wants about $200 for that repair.
John Nagle - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 11,414
