メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのFanを修理する際は、iFixitの修理ガイドをご利用ください。
  1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: 手順 1、 2の画像 1 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: 手順 1、 2の画像 2
    • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
    • Make sure the device is unplugged and fan blade is not spinning before starting.
  2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: 手順 2、 3の画像 1 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: 手順 2、 3の画像 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: 手順 2、 3の画像 3
    • Unscrew the clip-on stand that connects the fan. This can be done by hand.
    • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
    • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
    • The switch's settings:
    • Off (center)
    • Speed 1 (left)
    • Speed 2 (right)
  3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: 手順 3、 2の画像 1 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: 手順 3、 2の画像 2
    • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
    • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
  4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: 手順 4、 2の画像 1 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: 手順 4、 2の画像 2
    • Now that the blade is removed. The motor can now be removed from the other half of the housing.
    • Remove the two screws indicated in order to take the module out of the plastic.
    • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
  5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: 手順 5、 1の画像 1
    • That's it! There isn't too much when taking this device apart.
    • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
作成者
1人の作成者と共同作成されました。
Justin
メンバー登録日: 12/08/14
111 ポイント
1ガイドが承認済み
4 件のコメント
Hi How do you find the replacement switch?
sadeyealso - 返信
the switch melted….
sadeyealso - 返信
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - 返信
Is it possible to purchase a replacement blade?
Wayne - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 36
今までの合計 4,033
