必要な工具と部品
Remove four rubber grommets, They are glued well, so it requires some force.
The screw head is non-standard (Torx T9 or T10) with a "security pin".
If you lack the Torx bit, you can use a thin flathead screwdriver (appx. 1.5mm) to jam into the slot. :)
On my router, I could easily snap off that screw head pin, allowing me to use standard bits.
Serial interface (4 "pins") are unsoldered, and can be found in the top-right corner of the board (if the Ethernet ports were facing you).
A close-up image crop shows the 4 serial through-hole "pins". Pinout:
pin1 : VCC +3.3V
pin2 : GND
pin3 : TX
pin4 : RX
If you wish to connect using a USB TTL adapter, I suggest soldering female "jumper" wires and routing those outside the case. DO NOT CONNECT TO VCC (do not apply external power!)
The serial port is enabled by default, and you can watch Linux boot. If you Google around, you can find how to login to the console (this varies by OS installed on the router).
コメント 1 件
Hey man, jst wanna ask can you replace those antennas with hing gin onces?
