メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
We wanted to show off all the hard work the good folks at Blendtec have put into their machines, so we took apart their famous "Will it Blend?" blender!
We also made a video slideshow of the teardown!
この分解は修理ガイドでは ありません。 お持ちのBlendtec Total Blenderを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Our friends at Blendtec were awesome enough to lend us a blender for this teardown!
    • Our friends at Blendtec were awesome enough to lend us a blender for this teardown!
    • $400 gets you:
    • Their awesome "base" 1560W Total Blender (as if you can call anything with 1560 Watts "base")
    • Instruction manual
    • CD-ROM with product tour and video recipes
    • Lifestyles Recipe Book, good for many blenderiffic creations
  2. Fully digital controls, along with an LCD display. None of that "push-button" stuff found on $30 blenders. But will it blend? We were so anxious to open up this puppy, we never found out. We'll take the word of thousands of satisfied customers, as well as Blendtec's hilarious videos.
    • Fully digital controls, along with an LCD display. None of that "push-button" stuff found on $30 blenders.
    • But will it blend?
    • We were so anxious to open up this puppy, we never found out. We'll take the word of thousands of satisfied customers, as well as Blendtec's hilarious videos.
    • A mechanical switch on the back of the unit stops any bad ideas from turning into deadly ideas.
  3. You'll notice the absence of plastic. Other blenders use plastic shafts as a safety mechanism. If the blade gets stuck, the blade/motor connection will sever, as the plastic will either break or melt. The Total Blender has several electronic monitors that enable it to have a full metal shaft. That's how it transfers all that power to your ice cubes.
    • You'll notice the absence of plastic. Other blenders use plastic shafts as a safety mechanism. If the blade gets stuck, the blade/motor connection will sever, as the plastic will either break or melt.
    • The Total Blender has several electronic monitors that enable it to have a full metal shaft. That's how it transfers all that power to your ice cubes.
    • The splined connection between the motor shaft and the blades is perfectly suited to transfer the astronomical torque of the motor to the edge of the rotor blades.
  4. The bottom of the blender. Best place to go if you need your serial number. Remove the two Phillips screws (deeply) recessed into the bottom housing. Four side tabs hold the plastic bottom housing in place. Opening the blender is as easy as one, two, three, four.
    • The bottom of the blender. Best place to go if you need your serial number.
    • Remove the two Phillips screws (deeply) recessed into the bottom housing.
    • Four side tabs hold the plastic bottom housing in place. Opening the blender is as easy as one, two, three, four.
    • The bottom housing is very ventilated -- essential for cooling the 1560W motor housed within.
  5. There's another thin plastic cover underneath the main cover. Nothing too exciting yet.
    • There's another thin plastic cover underneath the main cover. Nothing too exciting yet.
    • The cover most likely directs air toward the vents in the bottom housing.
    • Notice all the free space. This is the type of device mostly unaffected by the trend to shrink all components as much as possible.
  6. Now onto the fun stuff. Connectors abound! We begin by pulling out the power switch -- can't be too careful nowadays, especially with the recession and all...
    • Now onto the fun stuff.
    • Connectors abound!
    • We begin by pulling out the power switch -- can't be too careful nowadays, especially with the recession and all...
    • Another spade connector lies underneath. We pulled that one out too.
    • Insert a spudger between the EMI power line filter and the case to separate the double sided tape. The unit comes right off after a couple of spudger twists.
  7. Onto the logic board, which may be the most important of all the internal goodies. It regulates all the aspects of operation and safety for the device. The logic board simply sits on brackets molded into the plastic housing. No screws! Disconnect a couple of spade connectors from it, and slide it out a bit to reach the control panel ribbon cable connector.
    • Onto the logic board, which may be the most important of all the internal goodies. It regulates all the aspects of operation and safety for the device.
    • The logic board simply sits on brackets molded into the plastic housing. No screws!
    • Disconnect a couple of spade connectors from it, and slide it out a bit to reach the control panel ribbon cable connector.
    • Disconnect the control panel ribbon cable from the board. This should almost free the logic board from the rest of the blender.
  8. Two more connectors, and the logic board is free to roam about the country! Two more connectors, and the logic board is free to roam about the country!
    • Two more connectors, and the logic board is free to roam about the country!
  9. Removing the speed sensor. Aptly named, the speed sensor monitors the speed of the spinning shaft. Should things get out of hand, the sensor will shut off the motor. The speed sensor uses inductive pickup to tell the control circuitry how fast the shaft is spinning. Inductive pickup is triggered by ferrous metal passing by in close proximity, causing a current to be induced in the pickup.  This is really the same effect used by an electric guitar to pick up the string vibrations.
    • Removing the speed sensor.
    • Aptly named, the speed sensor monitors the speed of the spinning shaft. Should things get out of hand, the sensor will shut off the motor.
    • The speed sensor uses inductive pickup to tell the control circuitry how fast the shaft is spinning. Inductive pickup is triggered by ferrous metal passing by in close proximity, causing a current to be induced in the pickup. This is really the same effect used by an electric guitar to pick up the string vibrations.
    • Blendtec informed us that the Total Blender includes what they call a "hammer-fire" system. The main microprocessor will trigger this system if it detects that the blade stopped spinning. The processor will send a series of strong electric pulses with the intent to free the blades from the obstruction. If that fails, it will shut off the motor to prevent any damage.
  10. Remove two Phillips screws (of the four holding together the entire device) from the brush/slip ring housing. These puppies didn't come out without a fight.
    • Remove two Phillips screws (of the four holding together the entire device) from the brush/slip ring housing.
    • These puppies didn't come out without a fight.
    • No wonder why -- they're over 3" long! Containing the inertia of the rotor spinning at 28,000 rpm is kind of important.
  11. Remove the single nut from the fan end of the shaft. A 3/8" Allen wrench conveniently fits into the splines at the other end of the shaft, making the nut removal a snap. After removing the nut, the fan simply lifts off the shaft.
    • Remove the single nut from the fan end of the shaft.
    • A 3/8" Allen wrench conveniently fits into the splines at the other end of the shaft, making the nut removal a snap.
    • After removing the nut, the fan simply lifts off the shaft.
  12. Use a flat blade screwdriver to 'walk' each of the two brass brush housings away from the motor shaft. After the brass brush housings are separated from their housing, the brush spade connectors simply slide out. After the brass brush housings are separated from their housing, the brush spade connectors simply slide out.
    • Use a flat blade screwdriver to 'walk' each of the two brass brush housings away from the motor shaft.
    • After the brass brush housings are separated from their housing, the brush spade connectors simply slide out.
  13. Removing the brush/slip ring housing exposes the support ball bearings at the tail of the motor shaft. The brass brush housing is connected to the pure carbon brush with a braided copper wire.
    • Removing the brush/slip ring housing exposes the support ball bearings at the tail of the motor shaft.
    • The brass brush housing is connected to the pure carbon brush with a braided copper wire.
    • The carbon brushes normally wear out before the rest of the motor.
  14. Lifting the stator out of the Blendtec. The weld connecting the stack of metal plates creating the frame of the stator is just plain beautiful.
    • Lifting the stator out of the Blendtec.
    • The weld connecting the stack of metal plates creating the frame of the stator is just plain beautiful.
  15. Tracing the small black wire to the bottom of the stator and peeling back the tape reveals... A thermistor!
    • Tracing the small black wire to the bottom of the stator and peeling back the tape reveals...
    • A thermistor!
    • The thermistor is used to monitor the temperature of the windings to avoid meltdown.
    • We're told that the motor temperature has to reach a maximum of 130 degrees Celsius (266 degrees Fahrenheit) before being shut off!
  16. Just look at this rotor. If looks could kill, you just might get shot. This a podracer engine is, hmm? Yeesssssss.
    • Just look at this rotor. If looks could kill, you just might get shot.
    • This a podracer engine is, hmm? Yeesssssss.
    • The two bearings are reported to be 608RS, which is a commonly available size. The upper bearing has a rubber sleeve over it in the photo.
    how I dissasembly the upper bearing????
    Alberto Alvarez - 返信
    OK.. I posted the same question earlier only to find out the solution in the next 30 mins.. So I wedged/pryed out the ring using a flat head screw driver. The ring tightly pinches the metal shaft and its only a matter of wedging it out.
    Sudhanshu Grover -
  17. The logic board. First picture shows the shininess of the logic board. The board is clear-coated to prevent condensation from attacking the electronics. The hi-res version of the board shows all the intricate details -- inductive pickup/rotor sensor plugs, the thermistor plug, etc.
    • The logic board.
    • First picture shows the shininess of the logic board. The board is clear-coated to prevent condensation from attacking the electronics.
    • The hi-res version of the board shows all the intricate details -- inductive pickup/rotor sensor plugs, the thermistor plug, etc.
    • The LCD panel is located on the back of the board, thus eliminating the need for any extra circuit boards.
    Where can to buy the new logic board?
    Cooper - 返信
    Hii .can u help me take out the bearing . I do not how to replace it
    Thong - 返信
  18. So ends the teardown of the Blendtec Total Blender. This is one of those devices that we are very leery about reassembling and using...
    • So ends the teardown of the Blendtec Total Blender. This is one of those devices that we are very leery about reassembling and using...
    • 13 Amps, generating 28,000 RPM (that's a 270 MPH blade tip speed) on a slightly-unbalanced shaft just strikes us as a bad idea!
    • The PS3 Slim works just fine after our teardown -- but it doesn't have razor-sharp blades.
    I for one would like to see it reassembled and tested...:)
    jmsaltzman - 返信
    You should put all the parts into another Blendtec blender, and see if they blend!
    justin600 - 返信
    justin600からの引用:
    Genius!!!! ifixit should ask blendtec if they will do a vid of that... :)
    will - 返信
    And looking at the board, all of that logic is carried out by a MicroChip PIC16F877 - Nice chip!
    Dan - 返信
    Blendtec blades are actually blunt.
    Vince - 返信
Miroslav Djuric
152,128 ポイント
143のガイドは作成済み
22 件のコメント
I bought a used ibc7 with a bit over 13,000 15 second cycles. The upper bearing was pretty gummed up and there was bearing dust (a rusty powdery substance) I have seen before when a bearing goes out blown through the engine compartment. looking at removing the socket? (the thing that receives the pitcher) shown in step 16. I think I need a vice with a 3/8 allen.
Also, I would recommend lubing the two bearings shown in step 16 now and again to increase the life of the blender. It would not require a full teardown. The rubber seals should pop open and a little cleaning and lube and all set. The bearings are 608rs which is a common available size.
kneelie - 返信
what about fixing the 64 oz. Container when the metal cutter breaks which is often. A new container costs nearly $80 and we would love to know how to repair ours. You skip the cutter breaking in the jar. Can you help?
willie king - 返信
There is a new blender jar for Blendtec blenders which comes with a removable blade assembly easy to replace, creates versatility . It's the Alterna Jar.
Thomas - 返信
I just looked and can't find what you describe.
Rich Frown -
Any info on the motor? What are the ratings? The logic board doesn't look like it sports any voltage conversion hardware - so is this a straight 120v/60Hz motor? What is the operating range?
thanks!
rootless - 返信
What about replacing the seal and bearing in the Wild Side jars? We have lost 2 so far and at $110 for a replacement it is starting to really hurt! I just removed the assembly with a chisel and hammer, the jars are tough!!!, to see how it is assembled. I don't see a way of disassembling it in a fashion that I could then reassemble.
Rich Frown - 返信
Can anyone tell me where to buy replacement parts on this machine? Looking for a new speed sensor!
Vinnie Mese - 返信
Did you get it?, I think buy parts unit for parts
JJa -
I want to know how to dissasemble the upper bearing...how to take apart the sleeve is it screewedD or put in by pressure???
Hello Alberto,
Did you finally figure out how to dis-assemble the top ring ? Also.. do you know where to buy any spare parts for Blendtec ? I called up Blendtec and they clearly refused to send out any replacement parts saying that I need to send the blender and then they will estimate the repairs and will fix it if I agree to the repair charges. Its a CON company who wanna charge the customers crazy amounts of money and won’t let anybody else touch the machine.
Anyways.. please let me know if and how did you dis-assemble the top ring and get the rotor out.
Thanks
Sudhanshu Grover -
We just had the same issue and figured out how to remove the rotor from the housing without damaging anything. Use the 3/8” allen head socket that you used earlier to hold the rotor still when removing the metal fan assembly. Push the 3/8” allen socket into the top of the rotor and tap with a hammer or, preferably, press out the rotor from the top of the housing. Be careful here, as the rotor will drop down out of the housing. Use only the force needed to press the rotor out, otherwise the housing can get damaged. Good luck. Hope this helped.
Stephen Shaw -
hello
can anyone tell me the vale of the capacitor CE2 next to the buzzer , I've just bought a broken express and someone has cut the cap off the board
thanks
jovius - 返信
The cap is 63V 100uF
Stephen Shaw -
I’ve removed the logic board and there is a clear silicone like substance on top of the cap. I’m going to order a cap and see if that solves my problem of loss of starting torque. Thanks for the teardown!!
Louis Webster -
thanks for the teardown
jovius - 返信
i am getting a code watchdog and timed out. what is that? and can it be easily fixed?
chas - 返信
Hello, would you mind letting me know where I can I buy the rotor part?
JENNY PARK - 返信
Will motor running without speed sensor?
where can you get parts?
JJa - 返信
My blendtec’s rotor spins but the socket doesn’t. How are the rotor and socket connected?
yuanming_zhang - 返信
OK. I was able to pull out the socket. It has some cracks. Anyone know where to get a replacement? I was thinking to weld it back but it would be difficult.
yuanming_zhang -
ours only stops now by using the switch on the back, We switch it on then press any button on the front and it goes full speed, pressing any button to stop it on the front has no effect. Going to tear It down look for any burnt signs on the electronics, inspect the brushes and lube the bearing. It is 12 + year old and been really great to us. Thank you for the tear down and comments
igolten - 返信
Ours makes insane sounds. Have taken it apart but couldn’t find the issue. The bearings run fine either end. Maybe it’s the fan hitting the inside of casing. Anyone had similar issue ?
zaki - 返信
コメントを追加
統計データを表示:
過去 24時間: 9
過去 7 日: 58
過去 30 日: 278
今までの合計 88,087
