メインコンテンツにスキップ
この分解は進行中です。 – 最新版を見るには定期的に再読み込みします。
必要な工具と部品
  1. Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: 手順 1、 3の画像 1 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: 手順 1、 3の画像 2 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: 手順 1、 3の画像 3
    • Here it is, ready to be torn'd!
  2. Audiovox CD-Radio Teardown: 手順 2、 3の画像 1 Audiovox CD-Radio Teardown: 手順 2、 3の画像 2 Audiovox CD-Radio Teardown: 手順 2、 3の画像 3
    • Pop off the battery cover and remove the 6 C batteries. Keep them though, they might still be good.
    • Unscrew the 4 highly visible screws with the medium size screwdriver.
    • You'll need a longer bit or a different screwdriver for the other 3 holes. I attempted to unscrew it with my bit based driver, but was unsuccessful.
  3. Audiovox CD-Radio Teardown: 手順 3、 3の画像 1 Audiovox CD-Radio Teardown: 手順 3、 3の画像 2 Audiovox CD-Radio Teardown: 手順 3、 3の画像 3
    • Work your way around the edge shown here with your fingers until a crack appears. Then it should be easy to lift the bottom off.
    • Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case.
  4. Audiovox CD-Radio Teardown: 手順 4、 3の画像 1 Audiovox CD-Radio Teardown: 手順 4、 3の画像 2 Audiovox CD-Radio Teardown: 手順 4、 3の画像 3
    • Now, hunt down all the little screws on the motherboard and remove them. There are 4 or 5, so if it doesn't want to move, it's probably being held by a screw or two.
    • Now that all the screws, are gone, slowly lift and remove the motherboard. I say slowly because there are still a few cables attatched to the underside.
    • Disconnect all cables that aren't soldered on.
  5. Audiovox CD-Radio Teardown: 手順 5、 3の画像 1 Audiovox CD-Radio Teardown: 手順 5、 3の画像 2 Audiovox CD-Radio Teardown: 手順 5、 3の画像 3
    • Now that those cables are removed, lift the motherboard up and out... or not.
    • The motherboard is attached to the LCD board via one of those pesky ribbon cables that's soldered on both ends and always seems to be covered in some sticky substance.
    • Lift the motherboard up so you have a good view of the LCD board.
作成者
5人の作成者と共同で作成されました。
platnicat
メンバー登録日: 10/11/09
44 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 20
今までの合計 1,358
