メインコンテンツにスキップ
この分解は進行中です。 – 最新版を見るには定期的に再読み込みします。
必要な工具と部品
  1. Asus Zenbook UX501 Teardown, Current Condition: 手順 1、 1の画像 1
    • Here is our shiny new UX501! we'll be tearing this laptop down!
  2. Asus Zenbook UX501 Teardown, Starting the disassembly!: 手順 2、 1の画像 1
    • Flip the laptop down.
    • Remove all the visible screws.
  3. Asus Zenbook UX501 Teardown: 手順 3、 1の画像 1
    • Remove the rubber stoppers from all four corners of the laptop.
    • Then remove the screws.
  4. Asus Zenbook UX501 Teardown: 手順 4、 1の画像 1
    • Remove the bottom case.
  5. Asus Zenbook UX501 Teardown: 手順 5、 1の画像 1
    • Here, we have access to the RAM, the WiFi card, and the SSD.
作成者
2人の作成者と共同で作成されました。
Andy Lin
メンバー登録日: 01/28/18
240 ポイント
1ガイドが承認済み
4 件のコメント
Hi. I have a UX501. I attempt to disassemble. However when I remove the rubber stoppers to get at the hidden screws, the screws are covered by a glob of thick black plastic. I can see one of the screws but it is buried very deep in the plastic.
Do you know anything of this? What is the best way to get through the plastic.
Stephen Boston - 返信
That adhesive is molded to spec, bottom tray to rubber feet, so don’t toss it, you’ll need it to reattach the rubber feet. I would recommend lifting the delicate sticky carefully, its near impossible but it’s cut specifically to match the screw holes underneath.
these instructions need to be amended since not all four rubber feet have screws beneath them.
c0BRA -
What Happened to the Rest of The Teardown-Steps?
FIVE (5) STEPS IS NOT A TEARDOWN
I need to remove my MBoard and prep it for shipping / repair.
c0BRA - 返信
Thanks cOBRA. That seems like a tough little job! Those guys are really stuck in there.
I have to take it on the road for a week so won’t get to it until I get back.
Stephen Boston - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 5,478
