メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのAsus ZenWatch 3を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Asus ZenWatch 3 Teardown, Let's begin: 手順 1、 1の画像 1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: 手順 2、 2の画像 1 Asus ZenWatch 3 Teardown, Band Removal: 手順 2、 2の画像 2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: 手順 3、 1の画像 1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: 手順 4、 1の画像 1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: 手順 5、 1の画像 1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: 手順 6、 1の画像 1
    • Battery
  7. Asus ZenWatch 3 Teardown: 手順 7、 1の画像 1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: 手順 8、 1の画像 1
    • Complete disassembly
作成者
1人の作成者と共同作成されました。
Reon
メンバー登録日: 02/01/13
141 ポイント
1ガイドが承認済み
20 件のコメント
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - 返信
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - 返信
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - 返信
What should I do if the power button doesn’t work?
MichaelKing10or - 返信
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 43
今までの合計 14,440
