はじめに
Use this guide for the following cases:
- You dropped the phone in water and need to dry it thoroughly
- You need to exchange the display for a working one
- You want to salvage parts
必要な工具と部品
Place the phone in front of you.
Turn it around and start by removing the holding clip.
Slide down the battery cover
Remove the battery by pulling on the two cables (green rectangle)
Use a torx screwdriver to remove four screws (red circles).
この手順で使用する道具:Tweezers$4.99
Pry open the phone from the side using a guitar pick or a spudger.
Be careful not to rip the two pieces apart because there are two connectors to be unplugged from the logic board (orange squares)
Use a pair of tweezers to accomplish this step and carefully remove the speaker as well as the headphone cable
Remove the two remaining torx screws that connect the logic board to the casing (red circles)
Use your tweezers to remove the remaining speaker cable on top
Then proceed to the ribbon cable for the display by rotating the phone by 90 degrees.
To remove the ribbon cable you must loosen the brown clip by gently pushing it up from both sides.
When the clip is loosened you may pull out the ribbon cable carefully.
