はじめに
Since the dawn of the iPad, Apple has remained resolute that the iPad is meant to be enjoyed sans-stylus. So when the iPad Pro debuted with a $99 must-have accessory in the form of a stylus, we were obviously intrigued. What makes the Apple Pencil so special? From what we've heard, it's got some nifty features, but we're more interested in what's going on inside that shiny white cylinder. Join us as we find out!
Looking for more gadget teardowns? Follow us on Facebook, Instagram, or Twitter to get the latest teardown news first!
必要な工具と部品
ビデオの概要
Apple's been tight-lipped on this pointer's finer points, but here's what we know for sure:
Bluetooth 4.1
Scans at twice the rate of finger inputs
Up to 12 hours of battery life
175 mm (L) x 8.9 mm (D)
Lightning connector for charging
There's been a lot of talk about Pencil. Let's sketch out a couple quick comparisons to some other styling styluses.
First: the Microsoft Surface Pen (from a Surface Pro 4).
Second: The original "iPad Pencil" by 53. It works specifically with their Paper app, and has a lot of the same features as the new Apple Pencil.
Apple was nice enough to include a spare tip, as well as a Lightning-to-Lightning adapter (a last minute addition) to save users from having to precariously charge their Pencils directly from their iPads.
The Lightning Connector cap snaps into place with magnets, but we're expecting most of these will be lost by next month.
Popping the cap off reveals a brand new, never-before-seen model number: A1603. Welcome to the world, Pencil!
Taking a nosedive into the Pencil, we start at the nib, which comes off quietly with a few quick twists.
A peek inside reveals a tiny metal bit sunk deeply into the tip, presumably to get as close to the screen as possible.
The digitizer on an iPad Pro should be able to determine the distance from each emitter to the screen—and from that calculate the angle of the Pencil relative to the iPad.
The linked Youtube video is not viewable - says “this video is private”(?)
We're eager to get a closer look at the
eraserLightning Connector, so we turn up the heat with our trusty iOpener. -
Even after a warm conversation with our iOpener, the Lightning Connector assembly still doesn't want to come completely out of its shell, but a quick tug frees it from the Pencil.
But at what cost... We definitely tore a flex cable...
Did you find any adhesive holding the guts to the case? Could you simply have pushed the guts out through the top instead of cutting the case or does it look like they molded the case onto the guts?
You can see the adhesive residue around the metal inner case, looks like hot-melt glue or something very permanent.
Tom Chai -
Yes, they could have, and there are videos online showing how to do it.
tooki -
Not all pencils have erasers. I still have a set of Swiss made artist pencils which do not have erasers. The programs the Apple Pencil will be used with all have digital erasers and undo capabilities. In my 40 years as an architect, I never used an eraser on the end of a pencil. I always used a separate eraser or an electric eraser. This is not a No. 2 pencil for 3rd grade. The author's comment is absurd and shows his or her lack of experience in using pencils in a professional setting. Sorry for venting, but I'm tired of people making this silly comment.
the tip is much more precise than the cap end. to "add an eraser" to the other end, they'd end up with a tip at each end, which sounds pretty absurd to me. frankly it's easier to tap an onscreen control to switch to eraser tool than it is to flip the pencil around in your hand and back
Wacom first introduced styluses with a pressure-sensitive eraser on the other end back in the 1990s. Nothing absurd about it. You can still erase with the sharp tip if you prefer.
tooki -
I would Love to not have to click more buttons to make a correction, plus some drawing techniques require a Lot of erasing, which is really annoying to have to operate software to switch between Every Single One of the thousand times in one session. I am an engineer, inventor, and occasionally artist, and at times I can spend All Day drawing. Now try to tell me that saving 10 seconds to switch functions times a thousand times in one day isn't a glorious feature to have! That's a couple hours of your life gone that day doing nothing but operating software while nothing happens. I don't care if it's inefficient from a product weight standpoint! I didn't get the pencil for how minimal it is; I got it to save me time because I'm an expert at fat-fingering touchscreen displays and this was the first way to bring precision to digital that I have with graphite or mouse. Two functional ends would be fantastic.
I’m an artist, and I just checked my 67 color pencils. Not one of them had an eraser. I have a Pink Pearl, an artgum and a kneaded eraser, but none of them are connected to a pencil. However, I am not an architect, so I cannot speak to that profession’s need for a connected eraser.
this is fun too read. When I bought this “pencil” I never expected or thought of the possibility of an eraser at the other end of the stylus. That might or might not have to do with me being an architect ;o) , but I kind of agree with those who think that the way the author of this tear down expects anything called a pencil to include an eraser at the opposite end from the tip is somewhat exaggerated. However, had there been one (or maybe a switch to shift the tip to an alternative function), I believe it would most likely have been an improvement.
Having thoroughly dissected the top and bottom portions and finding no obvious point of entry, we throw caution to the wind and break out the big guns.
Cutting through the
BicApple Pencil's plastic casing revealsan ink cartridgea metal casing.
any possibility of pushing the internal out from the tip?
This iFixit teardown is one big joke.
You can heat up the pen and push it out of the case like shown in this video :
https://www.youtube.com/watch?v=vLRpMny_... -
Whew—that was some work! Wiping up the plastic dust and pausing for a quick burrito break, we take a moment to appreciate the fruit of our efforts: Pencil sans case.
A quick glance along the inner metal cylinder reveals a tiny tri-point screw à la Apple Watch.
Below the tiny fastener, we spy some tiny contacts, which we assume are for Apple's internal testing.
After some more cutting and prying—and a brief conversation about laser cutters—we bust through a second (this time metal) layer.
We're rewarded with the antenna and battery assembly. No graphite at the core of this Pencil.
This tiny 3.82 V, 0.329 Wh lithium-ion battery holds just 5% of the charge of an iPhone 6s battery.
I gotta say, after using the Pencil for an extended period of time, it is nice to just be able plug it in and use it after 15 minutes vs. having to constantly swap out dead AAAA batteries (which my HP laptop stylus uses) due to prolonged lack of use.
Arthur Shi - 返信
You can just open the case with a screwdriver :
With the metal casing off, we pop off the antenna, decked in the familiar Apple black and gold.
We also get a better look at that ribbon cable we sheared earlier... It runs between the Lightning connector and battery, with some battery charging ICs along the way (we assume).
We've caught sight of more chips at the other end, so we ditch the battery and move to the fun stuff—like the teeeny logic board!
I nearly peed myself I was laughing so hard. Ermagersh!
My 1st gen Apple Pencil was not getting charged, so I contacted apple store, they asked me to buy new pencil saying this pencil battery is dead.
But local shopowner checked and find that battery is good but the problem is with the connector inside pencil. can anyone tell where can I get that part ?
What is this—a logic board for ants? Not quite, but weighing in at a whopping 1.0 gram it's definitely the smallest we've ever seen. With the hard work out of the way, we pause to see what makes the Pencil so smart:
STMicroelectronics STML151UCY6 Ultra-low-power 32-bit RISC ARM-based Cortex-M3 MCU
STMicroelectronics STMLS05 5-channel PMOS load switches
STMicroelectronics STM32L052T8 32-Bit ARM Cortex-M0+ Microcontroller w/ 64 Kb flash
Maxim Integrated MAX11290 24-bit delta-sigma A/D converter (likely)
Cambridge Silicon Radio (Qualcomm) CSR1012A05 Bluetooth smart IC
Bosch Sensortec BMA282 accelerometer
Maxim Integrated MAX44284 high precision current-sense amplifier
It is using a pretty low power ARM MCU, so it likely doesn't run a full OS
ianguy -
not all microcontrollers have an OS.
Likely just a bootloader inside
I was trying to figure out why they'd add bluetooth???
The pressure sensing happens on the pen itself not the screen, so it sends this data along the relative angle to the iPad
This does make me wonder why not an eraser on the other end...
Kalvinjj -
From what Apple has stated officially, it seems that the pen is actually passive in the process of determining position and tilt, in the sense that the Apple Pen has two signal emitters that the iPad Pro itself detects, and then calculates this information from. There probably is at least a minimum level of communication over BT to synchronize the process and generally facilitate everything. The only real sensor data that needs to be communicated is the 'force' level. This is done to offload as much detection and processing as possible from the pen, and minimize the activity of the BT radio. This allows for a much less powerful processor and corresponding battery to be used, generally making things (hopefully) more efficient and, of course, increasing Apple's profit margin. (If I have erred, feel free to correct me.) :)
JMC -
Think of a wii mote... what does a wii mote have?
Bluetooth for communication.
An accelerometer.
A gyroscope.
A camera for IR detection (distance).
So doesn't that ring any bells?
What does this thing have?
An accelerometer (maybe the EWX 11290)
A gyroscope (maybe L05286)
A sensor for pressure detection in the tip, including the chip.
So what is this? A wii mote in apple clothes.
would it be possible to retake the PCB picture with a ruler next to it with inches or Millimetres on it ?
We turn back to the metal casing to extract the pen nib and look for its sensor magic.
Peeling up one of the tiniest boards we've ever seen we find a set of three matching ticks. Three on the end of the pen assembly, and three on the tiny board.
If we had to hazard a guess, we'd say these helped sense pressure by measuring movement between these two parts.
Chances are this chip could tell us more about how this works...
It reads 8529043 343S00008-A1—likely a custom STMicroelectronics controller for the nib.
You can just open the casing with a screwdriver :
https://www.youtube.com/watch?v=vLRpMny_...esa punta se rompió, podría arreglarse?
Further teardown of the tip seems impractical, but that's okay: we have eyes everywhere, thanks to some slick X-ray imaging from our pals at Creative Electron.
Get a load of that tiny spring-loaded tip, and the two emitters buried within the shaft.
Just for kicks, we also imaged the itty bitty folded logic board, and the Lightning Connector and cap.
I use my Apple Pencil for precision drawing - I usually write with a 0.5mm mechanical pencil on paper. The size of the Apple Pencil tip is actually too big and gets in the way of seeing what I want to draw. I'm used to using a Cintiq pen on their tablets and their pen tips are MUCH narrower. I was actually thinking of milling down the last 2-3mm of the Apple Pencil tip to a diameter of about 1mm or so (which is the tip/barrel diameter on the Cintiq). The trouble is that the xray you show in figure 12 renders the plastic of the tip itself pretty much invisible so I'm unclear what room I have to play with. Do you have any other pictures at possible different exposures that do show the plastic of the tip?
Mick Mueck - 返信
May be new tips will come in the future for updates!!! Did you contacted Apple?
Vr1 -
So, that spring must be what I see poking out. I've used the pencil everyday on average of 5 hours a day and it has only been two weeks and it's worn down already. Hopefully replacement tips will be made available soon.
Apple Pencil Repairability 1 out of 10 (10 is easiest to repair):
The pen nib and cap can be replaced if worn out (or lost).
The pencil is clearly not meant to be opened or repaired; you can't get inside without destroying the device.
The layers of plastic and metal holding interior components are impossible to remove without shredding.
The battery, enough for a 12 hour run, is impossible to replace, giving the device a limited lifespan.
As for the battery, I'm sure Apple did some initial testing to make sure it could handle enough charging cycles to last longer than the normal time people would have one before they lost it. I'd love to see Apple come up with a Find-my-ApplePencil app. :-)
Absolutely! It'd be great if the the pencil could ping back its location using GPS, or cellular, or WiFi, or...wait we have low power bluetooth...hmm, I guess it could tell us if we are in the same 15 foot radius.
Now THERE's a good reason for having BT onboard :D
What is the range of BT? The "15 foot radius" comment sounds about right - BT would be rather useless for locating it, unless there is some "long-range-high-power beacon mode". As for GPS - how much would that cost? Are there combination Wifi/BT/GPS chips available for a reasonable cost? And then the antenna - can the same antenna receive signals on all three bands (or "on-chip" antennas? I don't know what the status of that tech is)
But I'd think the biggest problem with "find-my-Pencil" would be that it would have to always be on - thus sucking battery life (maybe they could put solar panels on the outside somehow? (see "Printable anodes for flexible organic solar cell modules" 2004 http://www.ec-ind.com/PEDOT/Printable%20... Don't know if that is still "current" though.)
jimwitte -
My dad had an apple pencil he never used and gave it to me for my new iPad Pro however it no longer holds a charge (it had never been used so perhaps never held a charge). Anyway took it to Apple and they said it would cost 110 CAD to fix since its past a year. So zero minutes of usage and no practical repair possible. Hope this stops people from wasting their money on the “Pencil”
Well said. Same situation here. I wish there had been a notice on battery maintenance on the product package. At least tell people that you need to discharge and charge every month or so. Throwing something that had hardly been used. Time for a better alternative.
My daughter broke the (apple) pencil lead. Seeing the pictures it seems that it’s screwed and there gives a little hope to find one and replace it. Dear iFixit (lovers) do you know where I could find this as to save from planet garbage the rest of this fully functional Apple Pencil
I have a pencil which doesn't work since the day I purchased it (problem is I purchasef it from another person, claims it is new)
went to iStore, said it was originally purchased 2 years ago.
let's say it was unused for 2 years, battery got drained, do you think it can be repaired or should I fcking throw it
This is an obvious case where having a replaceable battery would be better than an integrated battery. Apple is banking on customers upgrading to next generation product before the battery needs replacing.
I bought one of these pencils several years ago, when the iPad Pro came out. Worked. Then I didn’t use it until recently to work with my iPad mini 5. Well, it won’t charge. Says something about 3%. Apparently this is just junk now and useless. I won’t buy another. Apple should be ashamed of itself. You have to charge it regularly otherwise the battery dies and once out of warranty, you just have to buy another one. Piece of garbage. I hear the new version is just the same.
Rompí la punta de mi Apple Pencil 2 al intentar cambiar la punta. Se rompió por completo? Esto tiene opción de arreglo ? Cuánto puede costar en dicho caso ? Gracias
You can actually open the Pencil without completely destroying it :
50 件のコメント
I actually used our economy suction vise, it's pretty hefty and very stable :)
Could we get a tear down of a Surface Pen? #3 maybe #4?
I'd also like to see how the lightning connector flexes inside its base, like in the YouTube video that destroys the pencil by flexing it around connected to the iPad, would you open it up please?
“The battery, enough for a 12 hour run, is impossible to replace, giving the device a limited lifespan.”
Other lithium-ion batteries are rated for perhaps 1000 full-charge cycles, suggesting that a person using this pencil 8 hours every weekday would see a 6-year life.
That's a crude SWAG… perhaps you could estimate how “limited” the lifespan really is.
WaltFrench - 返信
It also happens that Lithium Ion degrades with time using it or not, undercharge, overcharge (granted, the charging circuit won't allow these 2), or temperature variations.
So it could go well down to ~2 years before needing too frequent charging.
Also since it's a pen, it will fall a lot, this will also lower this value.
Probably the pen will last long enough but it's definitely a product made to be replaced along the iPad or something like this.
Kalvinjj -
I would have given it a 0 out of 10 . Having to completely destroy something to service it is counter logical.
Apple is supposed to have the best engineers in the world but look what they've done.
If the Apple Pencil were made in my shop it would have a threaded end to open the case, a fully removable battery and an inner liner pcb that would slide out. Add a Qi power receiver for wireless charging and there would be no need for connectors of any kind.
Steve Jobs was right. Pens are bad.
It would probably also be twice as thick and 5 times heavier.
scottjl -
I don't blame Apple for not making it fixable. That's pretty hard at this scale. Two co-workers and I developed the active stylus for the DROID XYBOARD (http://www.a4c.com/product/motorola-droi...) a few years ago, and it doesn't come apart without a long soak in 100% isopropyl alcohol (0% water, obviously) to soften up the assembly adhesives. But at least it ran on an easily replaceable and surprisingly easy-to-get AAAA battery, getting about 6 months of life per battery.
Dan Wagner - 返信
The MCU part number is misstated in the article. Its an STM32L151... (not STML151...). It is part of ST Microelectronics ultra low power STM32L family. Relay a wonderful part to work with and fully capable of running quite a few different micro kernels and RTOS variants in addition to easily scheduling bare metal code using its fifteen level nested vectored interrupt controller.
Exactly the same as any other Cortex M in the world.
But what is the pressure sensitivity? I can't find it listed anywhere. This is the only video:
Repairing a pencil, really? I believe that repairing this is beyond the capabilities of anyone without a microscope, on account of it *being a stylus*. This shouldn't have a repairability score.
Whoa, Apple pencil is unnecessarily complicated re-invention of what's out there. Take a look at Samsung S-pen teardown. It's simplicity in itself, no parts to replace, no battery to replace. S-pen is brilliant.
The S Pen doesn’t have pressure sensitivity on a 12.9 inch screen nor is it Bluetooth.
jsbrock -
Pressure-sensitivity, which the S-pen does not have, requires either a battery in the stylus, or another layer of magnetic coils under the screen to enable a no-battery stylus. Clearly Apple decided not to go for the option that adds thickness to the tablet.
tooki -
My apple pencil started making a weird clicking noise and the nib is kinda crooked, I sent it to apple care and they said they wouldn't fix it ro give me a new one since it was accidental damage, but I've just been drawing with it for 2 months, any idea how to fix this or why this happened ?
Probably dislodged nib or cracked nib holder internally due to user pressure from the side. I noticed when using the pencil it is alot more prone to accidental side pressure due to the extra large tip. You could try using the replacement tip, but that might make it worse since chances are the nib holder cracked internally. (BTW, I am not the the author of the teardown article …just educated guesses on my part.)
The tip is a horrible design. A tiny piece of metal sticking out with a removable, read “movable,” plastic part to protect it is a recipe for disaster. The tip on mine was snapped off just from being in my bag, with the nib on. Like a cheap plastic pen. A $99 waste of unrepairable money. If Apple sells a product accessory for one of their products, they should make the product capable of holding and protecting it like the Samsung Galaxy Tab did with their pen. That was a very sleek design.
Does anyone know how to turn the pencil on and Bluetooth pair to the iPad Pro with out connecting it in the iPad Pro port? I have an iPad Pro I bought for $50 but the tristar is messed up I can charge the iPad on a flepow dock turn it on let it start up then the iPad says 1% then plug up an official iPad charger restart the iPad and it will be at 100% but the port does not work with the Apple Pencil or does the official iPad charge show the device charging. I just want to short the pencil on so I can pair it.
So, mine and my co-workers pencils died from what I can guess is lack of use and the battery dies down past the point the charger chips will let it charge. Does anyone know if I can jump start the charging process (I have done this before with a small trickle charge to get a lithium battery up to the safe charging point) using any of those 4 test points visible through one section of the tube? I have mine cut open exposing the metal inner tube but don’t want to cut that one open if there is any chance of getting to the battery in anyway.
Good news, I actually fixed two apple pencils. They really need a big note on the box, that you must charge once a month or so or the internal battery will die and not charge. One I found where power was easily accessible and forced a charge bypassing the charging circuit then it started working and charging. The other had a bad ground connection on the - side of the battery and I was able to fix that. Now I just need to turn some really nice pencil shells on my lathe ;)
Encouraged by James comment, bought two pencils very cheap on eBay. One had the tip broken, but a good battery, and connected to iPad. The front end is spot welded to the inner metal tube, so it can’t be replaced. The only thing that I could do was to cut it open to see how it how everything was placed. Despite getting detailed x-rays, it is impossible to cut it open with a dremmel tool without also damaging the tiny flex cables. I damaged the flex cables, But at least it gave me an idea about what’s where, and I thought that with the next pencil, I’ll do a better job.
On the other pencil, the LiPo had swollen and destroyed. Trying to just cut the inner metal shell was impossible. There are several places where spot welding has been done, including the battery terminals, and it is not possible to separate the battery from flex cable without damage, which I did. I don’t see how someone can do that without causing any damage. I also damaged the incredibly thin blue tooth coax cable.
Ahmad Rana - 返信
Muchas gracias por vuestros vídeos. También a los traductores. Saludos.
Question. How does apple replace the battery in the Apple Pencil, because according to the link below, they can and do change the battery for 30$
By opening it correctly (there are videos on YouTube showing how to do it) instead of the drunk gorilla approach taken here. The author of this teardown apparently had no idea that things can slide inside of other things, and thus chose to Dremel the plastic case, rather than to simply slide the contents out…
tooki -
i am done with apple product.
i have two phones, an iPad Pro 12,9 2nd gen, a Macbook air, Mac Pro, an Apple Watch , a dozen of Apple care pfff., and already bought my second pen and it stopped suddently juste a couple of month after the garantee.
I went to the LEMON store with my Apple Pencil so they can explain why my pen stopped working since I am able to pair it with my Ipad pro.
And the only thing they can tell me is I don’t know. It's better to buy a new one.
F. THEM.
Will I have to buy a new Apple Pencil because literally the pressure sensitive part the golden part is in half should I bring it to Apple and see what they do or just buy a brand new Apple Pencil and waste another hundred dollars I am so sad after one year of owning it I am dropped it and broken.
AppleTopic - 返信
So regarding the 1st Gen pencil’s battery dying, I have a Public Service Announcement.
I purchased the 1st Gen pencil about 2-3 years ago when we got a new iPad, misplaced it for nearly a year until the last week (Oct 2020). Obviously the Pencil had discharged and seems to have lost all capacity to charge. Apple’s Support page clearly states for Battery Replacement (Pencil replacement in reality) the cost is $29 for Out of Warranty. For any other reason, the cost is $79. Apple Support acknowledged this, but here’s the kicker. You have to send the Pencil in. IF Apple finds that indeed its only the battery, then its $29, BUT if they find something else its $79… the customer gets no say. Once you send it in you are authorizing a charge of up to $79, Apple doesn’t email you to ask if you just want to discard it if its over $29… they just bill you with no recourse (no refunds, no partials). What a horrible way to treat your customers.
So beware of Apple’s Pencil, my recommendation buy something else.
Should have unscrew a nut at the tip side... It is visible after you remove the tip of the apple pencil 1
I just dropped my Apple Pencil and the tip touched the floor. Then it’s not working anymore. What should I do? Is there anyway to fix it? Can it be fix just by changing the tip?
agh I got the same problem and sadly there was no way to fix it, I even asked apple and they charged me $70 for a replacement so i just ended up buying a new one sad life $100 wasted, be careful with the apple pencil its not very durable and very hard to fix :(
Do yall ever tear down the China’s finest knock offs from that Wish app?
добрый день, можете что нибудь посоветовать. у меня ручка упала и наконечник сломался. сделал он это по хитрому. половина осталась внутри ручки, самостоятельно ее не вынуть
Very interesting. Thank you for the good work. A question please, why would a pencil show signs on crack towards the nib? could this be battery outgassing? the pencil has had no accident and is used accordingly and only 3months old. Your opinion would be appreciated.
The end of my apple pencil broke off. (The end with the charger thing sticking out.) How can I fix this?
Has anyone managed to fix this pen ? :-D
Sonarpen Teardown Please
I now have 3 Apple Pencil carcasses. I dropped the 2nd one and the tip stopped working. I had misplaced the first one, bought the 2nd one, then found the first one. You guessed it… battery died in the meantime. I bought a used one for $40 from an online dealer that was advertised as working, but it wouldn’t charge past 3% (luckily they refunded my $ and told me to keep it.) I’ve ordered an open box unit from EBay for $65, hopefully it will work. I’m not ever buying brand new products again without reading ALL of the fine print. Apple should be ashamed of themselves for not including the “don’t let this item sit without charging it daily” info on the outside of the box. This made me super paranoid about my Apple Watch, too, but it seems to be ok sitting by the side of the bed (I have issues wearing it daily, it hurts my arm.) Anyone want some pencil carcasses, lol.
как всегда аксессуары от яблока дорогущие одноразовые изделия ( читай презервативы) очень сожалею что не могу купить что то того же класса но нормальное и ремонтопригодное
Can you do tear down of Apple Pencil 2 nd gen as to replace drained battery
Thank you for the break down! I have been researching why my Apple Pencil 2 will not charge. I was hoping I could replace the battery but you have proven that this is impossible. I appreciate everything you all do to help those of us who do our own repairs.
Christine Ayala-Sanchez - 返信
Apple will replace the battery for $29.
tooki -
