はじめに
How to take apart the Airport Extreme 802.11n.
必要な工具と部品
We got our new Airport Extreme 802.11n today. We decided to deviate from our standard modus operandi and run some benchmarks before we took it apart. (I know, I know-- our screwdrivers were lonely for a while.) This image is a sneak-peek to get your appetite whetted.
The new base station is amazing. We achieved a 10x performance boost, and a 3x usable range increase (significantly better than Apple's 5x/2x claims). Actual benchmarks are on the next page.
Included: Base station, the famous $1.99 install CD, smallish power brick, and a manual. No USB or ethernet cables.
Our office is a little bit spread out-- we have two snow 802.11g base stations and two Airport Express units. We may be able to replace them all with just one new base station!
maybe if you took the guts out of both of them and shoved them in a mac mini case, and wired them together externally, but connecting them together internally, would be impossible
We transferred two 35MB quicktime files (70 MB total). The first location was 5 feet from the base station. With the G base station, we had a reported comm quality of 56, and with the N base station the commQuality was 76. To get the commQuality, run the command `/System/Library/PrivateFrameworks/ Apple80211.framework/Versions/Current/ Resources/airport -I`.
Lift the guts of the base station out of the casing.
Take care to remove the small pieces of metallic tape between the case and the spring copper comb earthing strips in the case.
If you do not, it is a real fiddle to put them back in place latter (the tape will pull them out of the case ground strips)
Robert.
PS:In my case, I believe the onboard power converter is bust: the board sings when power turned on. So to trash it goes.
(external power supply is good), swapped with another to test).
Sad…
This is the top of the logic board. Interesting things: 3V (clock?) battery, two Samsung memory chips, and imprinted Apple part #820-1942-A. The processor is covered by a heat sink.
nullx86からの引用:
Any clue as to what the processor is on it? I wonder if its possible to use on of those Airport Extreme Mini PCI cards in a DIY Router kit?
Most likely, it is a proprietary ARM procesor.
So, is the wireless chipset (Broadcom I presume) removable? Why isn't this chip revealed? It appears to be in the fourth photo (in the upper right). I'm curious because there is a 802.1.11 ac chip for sale online. If the chipset is removable it would be worthwhile to attempt to try the new chip in these previous generation airport extremes.
This is the bottom of the logic board. Not much to see here--something large covered by another heat sink. At the top right is a plastic cover over the LED. Four ethernet ports, one USB port, a power jack, and a reset button. The Apple part number on the airport card is 603-9396-A.
Shameless plug:
iFixit sells iPod parts. It's easy to fix an iPod yourself with our iPod parts and free iPod repair guides.
We also sell Mac laptop parts. We've got virtually any part or upgrade for an iBook, PowerBook, MacBook, or MacBook Pro, at very competitive prices.
4 件のコメント
try heat shrinks
My 3rd gen extreme stopped working... No LED indication at all. Tried factory reset, no joy. No LED light illuminates, although It appears the power supply does push juice to the unit somehow, because only indication I have that there still may be life in it is that all LAN inputs blink in unison. Any thoughts? Reparable? Or BER (beyond economical repair)? Unit gave no indication of performance degradation before it stooped working.
Tim Traaen - 返信
i have a ipod and a mac mini and airport extreme
