メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのAmerican Era Electric Rice Cookerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. American Era Electric Rice Cooker Teardown, Rice Cooker Teardown: 手順 1、 1の画像 1
    • Start with the rice cooker unplugged, on a flat surface.
  2. American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 手順 2、 3の画像 1 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 手順 2、 3の画像 2 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 手順 2、 3の画像 3
    • Remove the lit and pot and turn upside down.
  3. American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 手順 3、 3の画像 1 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 手順 3、 3の画像 2 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 手順 3、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Remove the bottom plate by lifting one of the rubber feet.
  4. American Era Electric Rice Cooker Teardown, Remove Internal Screws: 手順 4、 2の画像 1 American Era Electric Rice Cooker Teardown, Remove Internal Screws: 手順 4、 2の画像 2
    • We're inside! Here's our first look at the circuitry. Let's take it apart.
    • Use a 3/8" or 8 mm flathead screwdriver to remove these six screws.
  5. American Era Electric Rice Cooker Teardown, Bend Tab: 手順 5、 2の画像 1 American Era Electric Rice Cooker Teardown, Bend Tab: 手順 5、 2の画像 2
    • Find the metal tab that connects the center button to the switch lever.
    • Use pliers to bend the metal tab into a U shape.
    • Align the tab with the slot so that it falls through.
  6. American Era Electric Rice Cooker Teardown, Remove Heating Element: 手順 6、 2の画像 1 American Era Electric Rice Cooker Teardown, Remove Heating Element: 手順 6、 2の画像 2
    • Turn the rice cooker right-side up.
    • Grab the center button and pull the heating plate upward. The gray metal ring should come out with it.
  7. American Era Electric Rice Cooker Teardown, Remove Temp. Sensor: 手順 7、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the screw connecting the temperature sensor to the heating element.
    • Remove the temperature sensor.
  8. American Era Electric Rice Cooker Teardown, Remove Center Button: 手順 8、 3の画像 1 American Era Electric Rice Cooker Teardown, Remove Center Button: 手順 8、 3の画像 2 American Era Electric Rice Cooker Teardown, Remove Center Button: 手順 8、 3の画像 3
    • Three bent metal tabs connect the center button to the heating element. Use pliers to flatten these three tabs.
    • Remove the center button from the heating element.
  9. American Era Electric Rice Cooker Teardown, Remove Control Panel: 手順 9、 2の画像 1 American Era Electric Rice Cooker Teardown, Remove Control Panel: 手順 9、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the screw that secures the control panel.
    • Remove the control panel from the outside of the rice cooker.
  10. American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 手順 10、 3の画像 1 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 手順 10、 3の画像 2 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 手順 10、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the screw securing the rectangular fiberglass plate. This should free the two light bulbs.
    • Use a Phillips #1 screwdriver to remove two screws securing the switch lever to the control panel plate. Remove the switch lever.
  11. American Era Electric Rice Cooker Teardown, Disassemble Switch: 手順 11、 2の画像 1 American Era Electric Rice Cooker Teardown, Disassemble Switch: 手順 11、 2の画像 2
    • Use pliers or hex wrench to hold the nut while using a Phillips #1 screwdriver to remove the screw holding the switch assembly together.
    • Pull the switch assembly apart into its parts. Careful not to lose any of these small parts!
  12. American Era Electric Rice Cooker Teardown, All Done!: 手順 12、 1の画像 1
    • And here we have it: a fully disassembled rice cooker.
Travis Taylor
メンバー登録日: 04/12/13
464 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G40
4 メンバー
37のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 32
今までの合計 4,079
