メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのAmazon Fire Stick 4kを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Amazon Fire Stick 4k Remote Teardown, Heat the remote to loosen the glue.: 手順 1、 1の画像 1
    • Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
  2. Amazon Fire Stick 4k Remote Teardown, Pry it apart.: 手順 2、 2の画像 1 Amazon Fire Stick 4k Remote Teardown, Pry it apart.: 手順 2、 2の画像 2
    • It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
  3. Amazon Fire Stick 4k Remote Teardown, Remove the seven motherboard screws.: 手順 3、 1の画像 1
    • Very easy to remove with the #0 phillips screwdriver.
  4. Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: 手順 4、 3の画像 1 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: 手順 4、 3の画像 2 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: 手順 4、 3の画像 3
    • Once the screws are removed, all the pieces come out easily.
作成者
1人の作成者と共同作成されました。
Nathan Ruffing
メンバー登録日: 05/24/21
792 ポイント
2のガイドは作成済み
2件のガイドコメント
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Scott - 返信
Took my firestick apart and this is what I found it is nothin like my spare one I have,why does it look like it does?is it possibly being used for something else???I can also send pics
Glenn McCulloch - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 65
過去 30 日: 273
今までの合計 7,515
