メインコンテンツにスキップ
この分解は修理ガイドでは ありません。 お持ちのAirvape Legacy Proを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Airvape Legacy Pro Quick Teardown, Airvape Legacy Pro Quick Teardown: 手順 1、 1の画像 1
    • Remove the top cloth material with heat
    • The tape that holds the fabric is no longer sticky after removal. But I found that heating it up again and reapplying the fabric works!
    • Remove four Phillips head screws
    • Use a spudger to lift off the plastic panel
  2. Airvape Legacy Pro Quick Teardown, Angled look at PCB: 手順 2、 1の画像 1
    • Just another photo
  3. Airvape Legacy Pro Quick Teardown, Under wireless charger: 手順 3、 1の画像 1
    • The wireless charging coil sits on a sticky pad, can be easily lifted with tweasers
  4. Airvape Legacy Pro Quick Teardown, Tear appart internal parts: 手順 4、 3の画像 1 Airvape Legacy Pro Quick Teardown, Tear appart internal parts: 手順 4、 3の画像 2 Airvape Legacy Pro Quick Teardown, Tear appart internal parts: 手順 4、 3の画像 3
    • Loose the two screws and gently tear appart the internal plastic body from the external metal case
作成者
2人の作成者と共同で作成されました。
ShellingRook27
メンバー登録日: 08/21/19
2,124 ポイント
7のガイドは作成済み
チーム
Repair For You Repair For You人のメンバー
Business
1 メンバー
12のガイドは作成済み
6件のガイドコメント
Looking forward to seeing this continue!
andypapster - 返信
nothing more with the teardown?
seedy53 - 返信
I think on FC he mentioned this was still his primary device and until he replaces it, he won’t do a further tear down.
andypapster -
Yeah, that is all for now. Like Andy said I'm still using this device and will do a full destructive teardown when I replace it. I'll update the introduction with that information.
ShellingRook27 -
I'm curious to know what kind of plastic is used in the construction of this device? Is it high grade PEEK good for a working temperature between 480°F and 500°F without off gassing, V.O.C.s? My air Vape Legacy Pro after 12 months of use, the vegan leather and hemp decals have delaminated from the plastic housing!
Please note it doesn't matter if it's food grade food grade plastic, which is mainly used for plastic bottles and storage containers Etc. Don't make the mistake I did, please avoid this purchase! Unless you're into off-gassing plastic into your system! After doing some research Air Vape will not confirm what plastic they're using! Extremely disappointing!
My DaVinci iq3 isn't without issues but at least it's made with premium parts using Aluminum, Stainless Steel and Zirconia
Ceramic! I have a brand new Apollo Legacy Pro in the Box any takers
$120 + shipping! U.S.A. only
Ghost Believer 👻
ghostbelievermv1gmail.com
-Ghost Believer- - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 114
今までの合計 2,176
