メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのAirplane Life Vestを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Airplane Life Vest Autofill Regulator Teardown, Life Jacket Overview: 手順 1、 2の画像 1 Airplane Life Vest Autofill Regulator Teardown, Life Jacket Overview: 手順 1、 2の画像 2
    • First picture shows whole life vest, on the bottom one red pull tag can be seen
    • Blue circle shows the inflation regulator, typically a CO2 bottle would be attached here
    • The purple square shows one of two manual inflation tubes
  2. Airplane Life Vest Autofill Regulator Teardown, Inflator Installation: 手順 2、 3の画像 1 Airplane Life Vest Autofill Regulator Teardown, Inflator Installation: 手順 2、 3の画像 2 Airplane Life Vest Autofill Regulator Teardown, Inflator Installation: 手順 2、 3の画像 3
    • The inflator was cut from the jacket for ease of disassembly
    • The second picture shows how the inflator sealed with the inside of the airbag
    • This was further cut away for better pictures
  3. Airplane Life Vest Autofill Regulator Teardown, Pull mechanism: 手順 3、 2の画像 1 Airplane Life Vest Autofill Regulator Teardown, Pull mechanism: 手順 3、 2の画像 2
    • To inflate the tab is pulled which moves a lever, which in turn pierces the CO2 bottle (more in the next step)
    • A shear pin going through the main body and lever prevents the lever from falling open. To break the pin a "jerk" is recommended
    • The second picture shows heat shrink over a crimp, this is to prevent any abrasion against the inflated life jacket
  4. Airplane Life Vest Autofill Regulator Teardown, Inflation Mechanism: 手順 4、 3の画像 1 Airplane Life Vest Autofill Regulator Teardown, Inflation Mechanism: 手順 4、 3の画像 2 Airplane Life Vest Autofill Regulator Teardown, Inflation Mechanism: 手順 4、 3の画像 3
    • Prior to pulling lever:
    • Mid pull on lever
    • Full pull on lever
    • When pulling lever a piercing pin goes from retracted, to fully extended, to retracted again. This opens the CO2 bottle and then clears the opening to allow quick inflation.
  5. Airplane Life Vest Autofill Regulator Teardown, Lever: 手順 5、 2の画像 1 Airplane Life Vest Autofill Regulator Teardown, Lever: 手順 5、 2の画像 2
    • The lever is installed with one pin pressed into place
    • A cam can be seen on the end of the lever, this causes the pin to only be fully extended in one position
  6. Airplane Life Vest Autofill Regulator Teardown, Piercing Pin: 手順 6、 3の画像 1 Airplane Life Vest Autofill Regulator Teardown, Piercing Pin: 手順 6、 3の画像 2 Airplane Life Vest Autofill Regulator Teardown, Piercing Pin: 手順 6、 3の画像 3
    • The piercing pin is installed going through the entire body of the inflator.
    • With a scribe it can be removed. There are 3 pieces: the pin, a spring (causing the pin to return after use), and an O-ring to only allow the air one path into the airbag.
    • With the pin removed a path is visible from where the CO2 bottle mounts to the lever.
  7. Airplane Life Vest Autofill Regulator Teardown, Valve into Airbag: 手順 7、 3の画像 1 Airplane Life Vest Autofill Regulator Teardown, Valve into Airbag: 手順 7、 3の画像 2 Airplane Life Vest Autofill Regulator Teardown, Valve into Airbag: 手順 7、 3の画像 3
    • A top cap can be removed to reveal a Schrader valve.
    • Schrader valve is used to allow only one way inflation into the airbag.
    • With valve removed a path from CO2 bottle to the airbag can be seen.
  8. Airplane Life Vest Autofill Regulator Teardown, Penetration into Airbag: 手順 8、 3の画像 1 Airplane Life Vest Autofill Regulator Teardown, Penetration into Airbag: 手順 8、 3の画像 2 Airplane Life Vest Autofill Regulator Teardown, Penetration into Airbag: 手順 8、 3の画像 3
    • With all other components removed the penetration into the airbag can be removed from the body.
    • This penetration is sealed into the airbag on its initial construction.
  9. Airplane Life Vest Autofill Regulator Teardown, All Components: 手順 9、 1の画像 1
    • A relatively simple mechanism stripped to individual parts
作成者
1人の作成者と共同作成されました。
Wieli
メンバー登録日: 01/08/23
2,141 ポイント
13のガイドは作成済み
コメント 1 件
Where did you get it?
Meow Purr - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 50
今までの合計 988
