メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのAccess HD Digital Converterを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Access HD Digital Converter Teardown, Access HD Digital Converter Teardown: 手順 1、 2の画像 1 Access HD Digital Converter Teardown, Access HD Digital Converter Teardown: 手順 1、 2の画像 2
    • Ah, the tiny little box. Reminds me in size of the new Apple TV. Yay for cheapo silver paint. What do you expect for 20 dollars?
    • To open it, you must remove 3 screws. 1 on the back, and 2 on the bottom behind rubber stickies.
    • There is also 1 clip you must undo on the back, it's visible.
    • The device takes OTA digital signals and converts it into analogue 480p. Ironic that it's called Access "HD". Composite or coaxial are your choices here.
  2. Access HD Digital Converter Teardown: 手順 2、 2の画像 1 Access HD Digital Converter Teardown: 手順 2、 2の画像 2
    • Once the cover comes off, you must disconnect the front button cable.
    • The front button board does not have much on it. Buttons, 2 color LED and an IR receiver.
  3. Access HD Digital Converter Teardown: 手順 3、 2の画像 1 Access HD Digital Converter Teardown: 手順 3、 2の画像 2
    • The Motherboard only takes up 2/3 of the case. The rest is empty plastic!
    • Unknown CPU with a clock of 100mhz and 16mb of on board RAM. Contains a composite video encoder and some kind of simple video controller capable of 480p resolution.
    • 4mb Flash DRAM which contains an unknown simple menu driven OS. No advanced features whatsoever.
    • Composite video output, Power in jack
    • RF Transceivers
    • Not much to this little device. It works well at picking up free over the air television. It tends to run hot, so the CPU must not be well designed for such a simple task as decoding MPEG4 streams.
作成者
3人の作成者と共同で作成されました。
Zenitar
メンバー登録日: 02/07/10
191 ポイント
2のガイドは作成済み
2 件のコメント
Taking the top off a product is not a teardown. :(
Ryan Guerra - 返信
I have 2 decoders that have failed,,this is one of them. Seems to have power but doesn't decode. Need to know how to test parts and replace.
Peter Cieply - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 6,545
