はじめに
Hey guys, instead of asking questions, im gonna solve a question with this guide.
The Telstra t-box was released in 2010 and was discontinued in 2018.
This is the first ever guide made for this item on iFixit, i might make more if i want to.
Anyways, here’ s a complete teardown on the Telstra T-box:
必要な工具と部品
Place your system on a flat surface and make sure all cables are disconnected from the system before dissasembly
Flip the device over and remove the hard drive cover (I dont have a hard drive cover on my t-box)
Peel off the warranty sticker and remove the 4 screws
Pull the casing off being careful of the cables connected to the case.
carefully disconnect those cables and proceed
After disconnecting the cables, you can remove the top half of the outer case.
remove the black tape holding the USB wifi adapter in place, then remove it the same way you would remove a USB stick
remove the ribbon cable on both ends and then carefully remove the IR sensor's board from the device
Please note that there is a metal tab thing holding the board in place, pull it a little bit and remove the board
Remove the screws holding the circut board in place
There is a screw on the hard drive cover next to the board, remove it
remove the hard drive and you should be able to get the main board
Take some nice pics of the t-box
To put it back together, do all these steps in reverse
5 件のコメント
I am no longer using this device with telstra-
Is there anything in there that could be used for anything else other than the t-box??
Or do I throw it in the bin!
@steve75385 Don't throw it it the bin! Send it to me. I would like to use the mechanical spinning thing that's encased in a silver aluminium box
ww w -
Is there a way to get recorded things off the hard drive? I have several movies on mine and the tbox won't power on any more.
