メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちの2010 Telstra t-boxを修理する際は、iFixitの修理ガイドをご利用ください。
  1. 2010 Telstra t-box Teardown, Preparation: 手順 1、 1の画像 1
    • Place your system on a flat surface and make sure all cables are disconnected from the system before dissasembly
  2. 2010 Telstra t-box Teardown, Remove case from bottom: 手順 2、 1の画像 1
    • Flip the device over and remove the hard drive cover (I dont have a hard drive cover on my t-box)
    • Peel off the warranty sticker and remove the 4 screws
  3. 2010 Telstra t-box Teardown, Opening it up: 手順 3、 1の画像 1
    • Pull the casing off being careful of the cables connected to the case.
    • carefully disconnect those cables and proceed
  4. 2010 Telstra t-box Teardown, Getting inside: 手順 4、 1の画像 1
    • After disconnecting the cables, you can remove the top half of the outer case.
  5. 2010 Telstra t-box Teardown, Disconnecting the USB wifi adapter: 手順 5、 1の画像 1
    • remove the black tape holding the USB wifi adapter in place, then remove it the same way you would remove a USB stick
  6. 2010 Telstra t-box Teardown, Removing the IR sensor's board: 手順 6、 3の画像 1 2010 Telstra t-box Teardown, Removing the IR sensor's board: 手順 6、 3の画像 2 2010 Telstra t-box Teardown, Removing the IR sensor's board: 手順 6、 3の画像 3
    • remove the ribbon cable on both ends and then carefully remove the IR sensor's board from the device
    • Please note that there is a metal tab thing holding the board in place, pull it a little bit and remove the board
  7. 2010 Telstra t-box Teardown, Removing the Main Board and hard drive: 手順 7、 3の画像 1 2010 Telstra t-box Teardown, Removing the Main Board and hard drive: 手順 7、 3の画像 2 2010 Telstra t-box Teardown, Removing the Main Board and hard drive: 手順 7、 3の画像 3
    • Remove the screws holding the circut board in place
    • There is a screw on the hard drive cover next to the board, remove it
    • remove the hard drive and you should be able to get the main board
  8. 2010 Telstra t-box Teardown, And you're done!: 手順 8、 3の画像 1 2010 Telstra t-box Teardown, And you're done!: 手順 8、 3の画像 2 2010 Telstra t-box Teardown, And you're done!: 手順 8、 3の画像 3
    • Take some nice pics of the t-box
    • To put it back together, do all these steps in reverse
作成者
1人の作成者と共同作成されました。
Bryn Trainor
メンバー登録日: 04/25/19
314 ポイント
1ガイドが承認済み
5 件のコメント
once you’ve taken it apart, can it be repaired? we have lost picture … can’t play ANY recoded material (100 hours worth) … what to do?
omarty - 返信
It’s exactly the same as few other boxes, this is a Netgem N8200, comes with different model designations depending of hard drive, etc… N8200-320-2T, N8200-160-2T, N8500-…
BITS2 - 返信
I am no longer using this device with telstra-
Is there anything in there that could be used for anything else other than the t-box??
Or do I throw it in the bin!
Steve - 返信
@steve75385 Don't throw it it the bin! Send it to me. I would like to use the mechanical spinning thing that's encased in a silver aluminium box
ww w -
Is there a way to get recorded things off the hard drive? I have several movies on mine and the tbox won't power on any more.
Deanne Roberts - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 27
今までの合計 2,117
