メインコンテンツにスキップ
« 全てのストーリーへ戻る
Samsung Washer Not Draining – Fixed Without Replacing the Machine
Appliance Kingdom - Appliances -
ストーリー画像
問題
Our Samsung front-load washer suddenly stopped draining water at the end of every cycle. Clothes were coming out soaking wet, and we were worried we would need an expensive repair or even a replacement machine. After receiving a repair quote that seemed too high, I decided to investigate the issue myself.
修理
Following the guide step-by-step, I located the drain pump filter and found it clogged with lint, coins, and debris. Cleaning the filter took about 20 minutes. After reassembling everything and running a test cycle, the washer drained properly and worked like new again.
アドバイス
Don't assume the worst when an appliance stops working. Many common problems have simple solutions. Take your time, follow a trusted guide, and always check the basic maintenance items before paying for a major repair.
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 55
今までの合計 151
