問題
The color scheme on my old screen started disinigrating and needed to be replaced.
修理
The repair went okay. It took a bit longer than anticipated because I couldn't get the ribbon cable in the hinge properly. That took me about an hour alone. I also swapped 2 screws, oops. No big deal though as they were about the same size and worked in the holes I put them in.
アドバイス
Double check that you have the screen faceplate on the correct way before trying to close it all up. It may cause frustration if you don't.
0 件のコメント
