問題
My battery was dead. It had to be plugged in or it would only last an hour or so...
修理
Really easy repair! Screws kept falling off off the table but I got it done. Really fun too!
アドバイス
Use tweezers to pull out the gold contact held down by the top battery connector screw. This is important and it WILL come loose when you remove the top screw, you will need to remove it and put it back together. Try both sides of the Plastic Opening Tool. The battery connector was easy to pry with one side, but that same side couldn't get out the battery itself. They are different and they can be used in some situations but not in others.
0 件のコメント
