問題
Large fissure on from the upper left corner to the lower left corner, and broken glass.
修理
iOpener kit gives you what you need to open up a ipad for presumably most repairs.
The demonstration video works well because the glass itself is intact. If like mine it is in poor condition be prepared to spend a long time scraping off shards.
It's not that the glass is easy to shatter, it's the fact the glue is so strong if you don't loosen it up enough it's only going to get worse.
I only got cut once!
アドバイス
During the prying off stages i managed to severe both the wifi antenna as well as the right GPS module. The guide here states to be careful around the wifi antenna. It doesn't communicate why though...
The cable conecting both the wifi and the right GPS are glued onto the front panel. In these two areas you want to approach from the edge of the iPad and push inwards pressing up against the inside of the glass. Sliding just outright cuts the cables.
0 件のコメント
