メインコンテンツにスキップ
« 全てのストーリーへ戻る
Late '09 27 inch iMac 2 TB HD Replacement (important discovery/remedy!)
Siegfried -
ストーリー画像
問題
Old HD got too full
修理
Everything went as smooth as can be, until...
アドバイス
Upon reconnecting all of the cables to my new 2 TB Enterprise grade HD I discovered that the thermal cable plug on my iMac had 4 slots but only 2 were used, 1 black wire and 1 gray wire. The problem was that I could NOT connect this to my HD because the remaining 2 blank slots had no holes or openings for the pins of the HD to go through. My remedy was to clear out the thin plastic webbing with the same paper clip I used to lift the LED screen out with. See photo. In my opinion, this info MUST be included in the guide. Hope this helps...
Spudgerの画像
Spudger
$3.99
Heavy-Duty Suction Cups (Pair)の画像
$14.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
