メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
« 全てのストーリーへ戻る
Found out Mac Repair Service Was not very careful to detail.
jamesm5807 -
MacBook Core Duo
MacBook Core Duo Upper Case Replacement
10 - 20 分
Moderate
問題
Bezel was cracked in assorted places.
The right and left arrow keys quit working.
The trackpad and select (long key below the trackpad) had issues.
修理
I followed the guides and used the plastic bag method to keep track of the screws, at each step I numbered the bag to the step in the instructions. I found that some of the screws were in the wrong place and that one of the screws was missing.
I had a little trouble getting the screws out of the battery case area.
I modified a phillips screwdriver to 60mm in length and did not have any more issues. The screwdriver you sold me was a bit toooooooo long. The Spudger worked great to get the plug out.
I had a three profanity moment getting it back in.
Took three tries to get the Bezel on correctly .
アドバイス
Go buy a can of compressed air first.
I used "Q" tips and dish soap to clean out the gunk.
I used a scotchbrite pad to polish the contacts
I had to file the little square inserts at the lower edge of the Bezel to get it in and have it fit.
Get a short screwdriver.
I had to use a "C"clamp and two wood blocks to compress the case together. I could not align the screws in the center of the case.
Spudgerの画像
Spudger
$3.99
Plastic Cardsの画像
Plastic Cards
$2.99
MacBook Front Display Bezelの画像
MacBook Santa Rosa/Penryn Upper Case with Keyboardの画像
$119.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
