iFixit Opening Picks set of 6
  • iFixit Opening Picks set of 6 / New
  • 360°
360
ご希望の商品が再入荷しましたらお知らせします。
Free Shipping on all orders $79.00 and up.
当社のショップを閲覧する
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
製品詳細
特長
特長
Pick your way to repair!
  • 6 very thin opening picks
  • Can be used for prying, sliding, separating, and air guitaring.
  • These picks are especially useful for prying open iPads and other glue-laden devices.
修理にまつわるストーリー
ユーザのアバター
Scott Cassio's Story Photo #885867
問題
Cracked front panel assembly
修理
The repair is pretty straight forward until the conclusion which states, 'But first ensure to place a narrow piece of tape over the copper/silver at the bottom of the digitizer to the left and right of the home button.'
Since there was no tape in those areas when I took . . .
ユーザのアバター
問題
Old battery couldn't hold a charge for long.
修理
Your tools made getting into the case easy. The only problem was getting the old battery out... Too much original glue!
The supplied tools made the job much easier.
アドバイス
Don't try to open the case with your fingernails!
ユーザのアバター
問題
Spider web screen
修理
Repair went very well instructions were plain enough was a little nervous of crushing a connector after the first one was in it was smooth sailing about an hour to do
アドバイス
Go slow take your time and follow instrutions
ユーザのアバター
問題
Accidentally dropped my phone right on the back.
修理
With a heat gun on low the glue softened up very easily. Needed something sharper and thinner to get under the glass but once I did it peeled off easily. Removed all the old glue with a knife to hopefully retail some water resistance.
アドバイス
Use the heatgun . . .
ユーザのアバター
問題
Screen was badly cracked after bing dropped on corner of iPad.
修理
Repair went smoothly. No major issues but needed another tool to make it really work.
アドバイス
Need to stay patient as it's tedious work getting the screen off. After that it's pretty easy. The plastic tool to pry open the screen from the edge isn' . . .
ユーザのアバター
問題
My wife's phone. She cracked her LCD screen
修理
The "Ifixit" video manual was to the point and quite accurate except a couple of things. On this particular phone the original adhesive refused to let go after heating the chassis several times. The iSclack was not strong enough to lift the rear cover loos . . .
ユーザのアバター
問題
My power switch was stuck. I bought a spare part off eBay.
修理
You guys rated the fixability a "1" and I completely agree. What a pain. I was able to get the switch replaced and the unit works except that when I was using the picks I pushed one in too far and it broke the digitizer membrane on the top-le . . .
ユーザのアバター
問題
Cracked Screen
修理
Great!
アドバイス
Becareful where you order your screens. I had to do this twice!!
ユーザのアバター
問題
Kindle would not charge unless you did the wire dance ( moved it all over) until you find the spot that if you're lucky will charge after you sit it down . Got to the point that I had to do it without moving the Kindle.
修理
Very well, you just have to pay attention to details.
アドバイス
Have a clean surface and all . . .
ユーザのアバター
問題
iPad 4th Gen WiFi with a broken front glass.
修理
The instructions were great except that for some reason, they assumed that I would be replacing an intact glass panel. Mine was broken in 4 lines, and every time I got to another break, it would shatter down to powdered glass and glue (Yes I know it is 3M . . .
もっと表示する
