iFixit 4 mm Screwdriver Bit
  • iFixit 4 mm Screwdriver Bit
$2.99
$2.99
ご希望の商品が再入荷しましたらお知らせします。
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
製品詳細
概要
概要
A bit on Bits
  • Supplement your collection or replace lost bits.
  • These bits are made of high quality, nickel-plated CRV Steel
  • Many of these bits are available in iFixit's very own 64 Bit Driver Kit and Universal Bit Kit.
  • If you are looking for a fancy driver handle to use with your new bits, check out our 64 Bit Driver Handle.
修理にまつわるストーリー
ユーザのアバター
HITGFRY's Story Photo #1301867
問題
Camera would not power up. I found that the CMOS battery receptacle solder points had come undone. I tried to re-solder but it didn't work. I think the poor connection damaged something else in the mother board. I purchased a manufacturers refurbished MB on eBay for $159.00.
修理
Replaced the main board. . . .
ユーザのアバター
問題
2 broken foot pads.
修理
Extremely easy. Spent more time cleaning out dust bunnies than replacing the foot pads.
アドバイス
Make sure that all the base attachment screws are laid out in an orderly fashion so reinstallation goes quickly and w/o a hitch
ユーザのアバター
問題
Damaged dock, slow phone.
修理
The repair went beautifully. Could have used stereo magnifiers, though. Did a cold reboot, then discharged to 10% followed by a non-stop charge to 100%. Had a fast phone again with long battery life.
After about a week, it wouldn’t take a charge unless the battery was dow . . .
ユーザのアバター
問題
Broken Screens or other broken parts
修理
well i fix all kinds of phones a lot of iphones and i lost 2 of my bits so i did not know what to do i contacted ifixit and they just happen to sell just the bits so i got 2 of them and love fixing phones im glad they had the bits i need
アドバイス
you need to order bits if y . . .
ユーザのアバター
問題
The battery was old and had gone through many cycles. It was not holding charge like it used to and would often require charging throughout the day.
修理
The repair went really well. The instructions were easy to follow as well as the plethora of resources on ifixit as well as youtube. The only annoying p . . .
ユーザのアバター
問題
Battery would not hold a charge for very long.
修理
Very well. I watched a video online and it explained exactly how to change the battery. The kit had everything I needed and it was reasonably priced.
アドバイス
If you have a phone battery that won't hold a charge, buy this kit. It has everything you need and you . . .
ユーザのアバター
問題
Battery needed servicing. I was still running the original battery, but mainly on the charger 24/7.
修理
Followed the guide and the replacement was very easy.
アドバイス
You will need a Tri-wing screwdriver. Luckily I had a frend that had one. If not for him, I would have had to delay the replacement until I foun . . .
ユーザのアバター
問題
My PS4 fan sounded like a jet engine.
修理
The repair went good.
アドバイス
I don't have any advice.
ユーザのアバター
問題
My iPhone 4 battery was bad.
修理
Extremely easy!! All went as expected!
アドバイス
Don't be intimidated! It's not difficult for anyone with basic mechanical skills.
ユーザのアバター
問題
I had a bad battery
修理
Quick and easy instructions - step by step
アドバイス
buy the whole kit (battery and tools) for convenience.
もっと表示する
