Universal Bit Kit
  • 360°を閉じる
  • 360°
360
Universal Bit Kit
The complete bit set for any repair enthusiast.
$85.99
$85.99
ご希望の商品が再入荷しましたらお知らせします。
新しいバッテリー=より速いiPhone
最低購入価格 $16.99
製品詳細
特長
特長
  • 128 steel bits in both 4 mm and 1/4" sizes for precision work and large torque application.
  • CNC machined aluminum driver handles for both 4 mm and 1/4" bits provide plenty of grip while driving screws.
  • Elegant oak case keeps all components secure and conveniently displayed.
Bit List
  • Phillips 000, 00, 0, 1, 2, 3
  • Flathead 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 5, 6, 7, 8 mm
  • Torx T2, T3, T4, T5
  • Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
  • Hex 0.7, 0.9, 1.3, 1.5 mm
  • Hex Security 2, 2.5. 3, 3.5, 4, 5, 6, 7, 8 mm
  • Hex SAE 1/16
  • Hex Security SAE 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
  • Nut Driver 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 mm
  • Nut Driver SAE 1/4, 3/8
  • Square 0, 1, 2, 3
  • Pozidriv Pz0, Pz1, Pz2, Pz3
  • JIS J000, J00, J0, J1
  • Torq-set 6, 8, 10
  • Tri-wing 0, 1, 2, 3, 4
  • Tri-point Y000, Y00, Y0, Y1
  • Pentalobe P2, P5, P6
  • Clutch 1, 2, 3
  • Gamebit 3.8, 4.5 mm
  • Spanner 4, 6, 8, 10, 12
  • Triangle 2, 3 mm
  • Spline M5, M6, M8
  • Oval Bit
  • SIM Eject Tool
  • Magnetic Pickup Tool
  • Schrader Valve
  • Hook and Loop Fastener
  • 1/4" to 4 mm drive adapter
  • 1/4" driver to 1/4" socket adapter
  • 1/4" driver to 3/8" socket adapter
  • 1/4" socket to 1/4" driver
製品ビデオ
修理にまつわるストーリー
ユーザのアバター
Benjamin Rodriguez's Story Photo #1013595
問題
Battery is damaged
修理
Quite easy
アドバイス
If you put more guides that are good to learn
ユーザのアバター
問題
User spilled coffee onto their keyboard, computer shut off.
修理
Better than anticipated. First in hour repair of a logicboard.
アドバイス
Magnetic board to organize screws and the 128-bit kit to have everything.
ユーザのアバター
問題
My Apple watch screen suddenly came off of the frame as the adhesive material must have some how been damaged. So the screen was hanging from the frame by a few tiny connections!!!!
修理
I took it to Apple to get it fixed and they quoted me 3 weeks time plus 275$+13% tax to fix it as I was out of warranty . . .
ユーザのアバター
問題
The Problem started when my dog knock over water on my wife mac.
修理
The repair went well, though i should of bought the ifix it business tool kit because some of those cable are really small.
アドバイス
I never done a repair that did not had any remaining screws. Just follow the step that Ifix it provides and you w . . .
ユーザのアバター
問題
It had been dropped
修理
My blind grandmother could have fixed it....
アドバイス
If you need help go to ifixit
ユーザのアバター
問題
The battery of my Macbook Pro 15 - 2011 died on me.
修理
It took about 7 min and was great.
アドバイス
Just read the instruction before you order.
ユーザのアバター
問題
The current 500GB drive had run out of space, so we upgraded to 4T.
修理
Everything went well, however a word of caution. The video cable mount is very tiny and you need small hands to reseat it.
アドバイス
You don't need to remove the LCD screen, you can reach the screws that hold the drive in place by simply liftin . . .
ユーザのアバター
問題
Problem - Daughter's Boyfriend Electrical Engineer - Idea for gift!
修理
He loved it! Several times while he was at our house, I found him simple pulling out each bit and playing with the two drivers. My daughter said he had to hide them from his Dad. Maybe Dad will get a set of his own.
アドバイス
Oh yes, advice... . . .
もっと表示する
この商品を購入された方は次の商品も購入されています。
