TR7 Torx Security Screwdriver
  • TR7 Torx Security Screwdriver
  • TR7 Torx Security Screwdriver / iFixit - Made in Germany
$6.99
$6.99
ご希望の商品が再入荷しましたらお知らせします。
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
製品詳細
概要
概要
Use this precision Torx TR7 screwdriver for DIY or professional electronics repair. The screwdriver head is also known as the Torx Security TR7 and is compatible with standard Torx T7 fasteners.
The iFixit Torx TR7 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Torx TR7 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
修理にまつわるストーリー
ユーザのアバター
問題
I had four screws strip their head. No fault of IFIXIT.
修理
I got a stripped head repair kit for Xmas and was able to get the screws out and then back un.
アドバイス
Do not think anyone will have the problem I had but if you do get a stripped head kit. The tools from Ifixixit are all you need.
ユーザのアバター
問題
I had dropped my laptop because my dog jumped on my lap and since then the right speaker sounded blown.
修理
I took the afternoon of, poured a glass of cold beer and sat down with the patient. Carefully I followed the instruction on the website through my IPad. Using the tools I bought off this site, I op . . .
ユーザのアバター
問題
too expensive to send to Toshiba. Decided it would be a simple procedure to do it myself - with the right tools
修理
Very well. researched procedure on internet and replaced battery very easily
アドバイス
Do lots of research before attempting repair. Most hardware issues then become easy to fix.
ユーザのアバター
問題
Display screen change.
修理
Well. Easy to use products.
アドバイス
Spudger is very light build, it is not to be used to apply strength or else it will break in no time, which happened to me.
ユーザのアバター
問題
I wanted to upgrade my Macbook Pro's SSD from 128gb to 256gb.
修理
I followed iFixit's step by step instructions, and everything went smoothly.
アドバイス
I know it might be a little scary doing this the first time (It was for me). Don't worry to much about hurting the machine though. Macs are built strong and are . . .
ユーザのアバター
問題
in repair centre it coast twice more and takes two months. I don't know peoples who were satisfied such repair
修理
today i fixed my macbook pro. it took around 2 hours. With your guide and instruments it was very easy.but i got 2 item superfluous.First it is plastic pull tab of the microphone ribbon cab . . .
ユーザのアバター
問題
Motorola XOOM Won't Charge or Power On
修理
Read on a forum that one person said that unplugging the battery and reconnecting it would solve this problem so I ordered the 3 items from IFixit that I needed to get inside. The repair was a success. I removed the battery connection inside and reconnected and . . .
もっと表示する
この商品を購入された方は次の商品も購入されています。
