Spudger Retail 3 Pack
  • Spudger Retail 3 Pack
$8.99
$8.99
ご希望の商品が再入荷しましたらお知らせします。
PCラップトップ用バッテリー
An easy fix for a big power boost.
ショップを見る
PCラップトップ用バッテリー
ショップを見る
製品詳細
概要
概要
Tough antistatic tool used for working on electronic devices and doing DIY electronic repair. It's an essential tool for everything from repairing a broken smartphone or tablet screen to replacing an old battery or hard drive. Tough (and heat resistant) enough for using as a soldering aid.
修理にまつわるストーリー
ユーザのアバター
Jill Benrey's Story Photo #1319762
Jill Benrey's Story Photo #1319764
Jill Benrey's Story Photo #1319761
問題
Fan was overheating xbox. Son couldn't play his games with out his xbox shutting off.
修理
Fan replacement went pretty well. I did watch a couple youtube videos which helped me not disconnect some things that can be fussy and break.
アドバイス
Fun to show your kids you had a life before being a mom and you actually k . . .
ユーザのアバター
Audrey Sampson's Story Photo #1336642
問題
As you can see, the battery in my MacBook was swelling and had pushed the trackpad out of the case. Apple support said that my device was too old to service in store, so I should find an authorized repair shop. But I live 2-3 hours from the nearest options, so I asked my office IT guru if he knew of . . .
ユーザのアバター
問題
The Xbox kept losing wifi connection sporadically. At boot up. So I kept rebooting it until it connected. Very random. When the wifi was down, it wouldn't even see my neighbor's wifi. So I suspected the wifi card was bad. Sometimes it worked, sometimes it didn't.
修理
The repair was easy using the guide. . . .
ユーザのアバター
問題
I had a Late 2008 MacBook 13" (5,1) laptop and was saddened to realize that part of the keyboard was not working anymore. I wanted to get the laptop working again so I could give it to my son to use as his first computer.
I found this "Guide in Progress," "Upgrading your 2.0Ghz 13" Aluminum Unibod . . .
ユーザのアバター
問題
Old battery would need charging every day. I read a lot
修理
Concise and clear.
アドバイス
Don't be afraid to try. I hope to get 5 more years out of my Kindle 2
ユーザのアバター
問題
Hard drive had failed OOW
修理
Repair went well.
BTW, I did not do the dual drive install, just replaced the original.
Only issue was The pointing devices acted weird and bluetooth was not behaving as expected. I posted the problem asking for solutions and someone explained that it sounded like there w . . .
ユーザのアバター
問題
Controllers nor wifi would connect to the Xbox
修理
It went fantastic
アドバイス
Be careful if you have a broken thumb
もっと表示する
