修理を始めるには
修理する権利
パーツ&ツール
Soldering Station Hakko FX888D-23BY
  • Soldering Station Hakko FX888D-23BY
$99.99
$99.99
ご希望の商品が再入荷しましたらお知らせします。
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
製品詳細
概要
概要
This station includes 1 general purpose tip.
The Hakko FX-888D is an updated digital version of the popular FX-888 and includes several new features. User selectable preset temperatures and digital calibration simplify user setup and operation, and the new password protection and low temperature alarm provides process control and helps protect against cold solder joints.
• Adjustable temperature control
• Temperature range 120° - 899°F (50° - 480°C)
• Digital display shows °F or °C
• Maintains idle temperature within 1.8°F (1°C) when set to 400 - 899°F (200 - 480°C)
• Ceramic heating element and sensor ensures rapid heat-up temperature and fast thermal recovery
• Password protected temperature setting functionality
• Preset mode allows you to store up to five (5) preset temperatures
• Slender, lightweight ergonomic iron handles
• Compact design takes up less bench space
• Wide selection of tips available for soldering SMD and through-hole applications
• Use with Hakko T18 series tips
• ESD Safe
修理にまつわるストーリー
ユーザのアバター
問題
The hdmi port was damaged
修理
The repair guide was VERY helpful and well made. Was very easy to follow step by step.
アドバイス
1. hdmi port as 18 pins that have to be sooo well align to be at the good place. Take your time!
2. Ruban connector of the blue ray driver is under the device and not easy to connect. Easye . . .
