Pro Tech Screwdriver Set
$49.95
$49.95
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
特長
特長
One screwdriver set to rule them all
  • 15 fixed-bladed drivers make a wonderful addition to any workbench, eliminating lost and misidentified bits.
  • Specifically chosen by our technicians, these drivers will work great for 90% of electronics repairs.
  • High-quality SVCM (Silicon, Vanadium, Chrome, Magnesium) steel shafts with rubberized handles and spinning caps make these drivers iFixit staff favorites.
  • Bundled together in a custom-designed tool roll, this set collapses to a small 5" x 6.5" x 2" bundle.
Set Contents
製品ビデオ
修理にまつわるストーリー
ユーザのアバター
問題
I have a 2011 Macbook Pro 13 that would not charge the battery. After serveral phone calls to Apple Help and a trip to "certified" Apple repair center, I was told that they had to send it out to repair ("probably" the power board). Estimate $800, No thanks. Then I found ifixit! After getting the pa . . .
ユーザのアバター
問題
The battery was completely dead after a long time of degraded performance.
修理
It was much easier then I had thought, after hearing too many exaggerated stories about the great difficulties with repairing MacBooks.
アドバイス
Only this: Have a can of compressed air at hand and blow the dust out of the fan while you . . .
ユーザのアバター
問題
Battery wasn't keeping a charge for very long so I was keeping it plugged in all the time.
修理
It was a piece of cake, I had read the directions a couple of times and they were so clear I didn't need to refer back to them while I was doing the job
アドバイス
To keep the screws straight to put them back in the right . . .
ユーザのアバター
問題
When Apple recalled my late 2009 iMac because of hard drive issues, I was busy / procrastinating / lazy / traveling / etc. The computer still worked, and while everything I had was backed-up and in the cloud, I couldn't upgrade to Yosemite because it recognized the serial number of a recalled HD a . . .
ユーザのアバター
問題
The battery would not take any charge. I ordered a replacement battery for the laptop but I needed special screwdriver set to remove the screws from the MacBook Air bottom plate and battery module.
修理
The set of tools that I ordered from iFixIt made things a lot easier. What I needed was just there. . . .
ユーザのアバター
問題
Was able to replace the battery using this tool very precise and feels like a professional product
修理
Repair was a success this product is good.
I know its a little too much but it does feel good to the hand and the magnetic end helps a lot when picking up the screws.
アドバイス
Really great product but i hope the . . .
ユーザのアバター
ユーザのアバター
問題
WiiU Controller had a massive gash in the Digitizer preventing it from working properly
修理
Was fairly simple after I found a properly detailed teardown video, there was a number of videos that completely skipped a few important steps of which I'll explain in a bit of detail below but besides those few i . . .
ユーザのアバター
ユーザのアバター
問題
I wanted more storage space on my MacBook, 128 GB to 512 GB.
修理
Swapping the drive was easy, but reinstalling the operating system was difficult. I got the error that it couldn't detect the hardware and thus couldn't install the operating system. Disk Utility showed the drive showing up properly and for . . .
もっと表示する
